View Thanks
David Offline
#1 Posted : Thursday, 30 October 2008 4:01:31 AM(UTC)
David
Hi Fellas,
Last weekend I found an LJ GTR motor, JLXXXXXX - minus head and accessories - in a gully in the bush. Not sure if it is any good. At a glance it has corrosion, and has probably been there for months.
Was wondering if it would be worth anything if it is able to be rebuilt.
Is there a demand for these motors? I gather they were not too quick. What would a rebuildable bottom end be worth?
Im still looking for an LC GTR 173S. Maybe further up the gully!
David
CherryBomb Johnston Offline
#2 Posted : Thursday, 30 October 2008 5:20:23 AM(UTC)
CherryBomb Johnston
Im thinking not... But I dont follow the trends of died-in-the-wool GMH restorers either.
If I recall they were a simple upgrade with slight cam lift and twin down draft carb?
But if the block has been striped and dumped its a good bet its cactus....
"Because stock sucks"
#3 Posted : Thursday, 30 October 2008 6:17:39 AM(UTC)
the LJ GTR motor was basically a standard 202, diff engine
number prefix, round chrome airfilter, chrome rocker cover
but only had standard single throat carby, did have cast iron
headers
plenty of grunt in light weight LJ
the earlier LC GTRs had twi
#4 Posted : Thursday, 30 October 2008 6:47:35 AM(UTC)
single throat? srsly?
adam PERTH Offline
#5 Posted : Friday, 31 October 2008 8:37:24 AM(UTC)
adam PERTH
i sold one 18 months ago (complete, not running for $3500 )
WANTED:
QR 662xxx
1984 WB oyster crashpad
1x15x8 Cheviot armoulite HQ
pair of 15" Dragway centrelines suit HQ
David Offline
#6 Posted : Friday, 31 October 2008 9:02:06 AM(UTC)
David
Thanks for responses Fellas.
Adam, wasnt that an XU1 motor? This is just GTR.
David
adam PERTH Offline
#7 Posted : Sunday, 2 November 2008 3:39:55 AM(UTC)
adam PERTH
it was a JL prefix.
JL 15xxxx from memory, which i think puts it around 5/72.
mine was a complete motor, including GTR air cleaner (with slot).
WANTED:
QR 662xxx
David Offline
#8 Posted : Sunday, 2 November 2008 6:25:22 AM(UTC)
David
Thanks Adam
Sounds like it would be worth my while grabbing it and pulling it apart to see if it has any future.
The number is JL2788.. What date?
David
adam PERTH Offline
#9 Posted : Tuesday, 4 November 2008 3:34:37 AM(UTC)
adam PERTH
the casting date is behind the oil filter.
add some time, 6 weeks? for build date of car?
shouldnt be too far off.
JL 27 xxx is getting on a bit, like 4/73?
SOmeone will know who has the torana vin CD...
WANTED:
QR 662xxx
#10 Posted : Tuesday, 4 November 2008 8:39:21 AM(UTC)
Guys
Im overseas so not logged in.
Being an xL prefix means its a stock standard 202. BUT, having JL does not just mean it is from a GTR, as the 202 was optional on other LJs later on in the model run.
David Offline
#11 Posted : Wednesday, 5 November 2008 8:43:07 AM(UTC)
David
Thanks Byron, Adam,
So it is a standard 202 that might or might not be from a GTR! There must have been plenty of them made, so I guess I have not discovered a treasure. I think Ill just leave it in the ditch.
David
#12 Posted : Wednesday, 5 November 2008 9:37:09 PM(UTC)
It is the right prefix for a GTR though, so it is worth having. It is most valuable to its original car if that car was a GTR. Email me the engine number and ill see if I can find its original car.
______________________________________________________
David Offline
#13 Posted : Saturday, 27 December 2008 4:14:27 AM(UTC)
David
Hi again Fellas,
I hope Santa was good to you, and I hope Ricky and his boys can improve a little on their current cricket form.
I grabbed the motor, pulled off the sump and pulled out the pistons. Everything inside was still well oiled, so no corro
#14 Posted : Sunday, 28 December 2008 4:19:29 AM(UTC)
David
I sent you this in an email a while back. Here is the info if you didnt get it:
It originated in an LJ 2369 (S 4door) with the PSN L235180 (VIN suffix).
Built on 16/4/73, dealer code 000.
Was a 3 speed manual with 3.36 diff.
_______
David Offline
#15 Posted : Thursday, 1 January 2009 11:01:25 AM(UTC)
David
Thanks again for your help Byron.
I did not get your email. My wife changed our email address about then - we were getting too much spam!
Ill put the block on ebay. Maybe someone will want it.
David
Guest (6)
