#1 Posted : Friday, 31 October 2008 2:56:39 AM(UTC)
I have just fitted a ProComp Motorsport- Gilmer Drive to the 308 in my VH SL/E with power steering. Due to the fact that my water pump has a long nose on it the water pump pulley is sitting too far out and now the belt isnt lining up as it should be. Can anyone recommend a decent water pump with a short nose? According to Pro comp the kit suits long and short nose water pumps but there is no further adjustment possible and it's not lining up.
Cheers, Brett
basketcasebear Offline
#2 Posted : Friday, 31 October 2008 5:09:37 AM(UTC)
basketcasebear
hey brett,
do those gilmer drives allow for PS,,AIR CON, as well as water pump alt, etc, whada they worth?
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my f
DOH!!!
#3 Posted : Friday, 31 October 2008 5:17:39 AM(UTC)
im not sure but red motor water pumps are 12mm shorter than WB-VS. i dont know why they changed the length but since your not using the other stuff bar the power steering. i can see any problems. if your using the real glimore the water pump pully does to
#4 Posted : Friday, 31 October 2008 5:42:32 AM(UTC)
The one i have will run waterpump, and alternator and gives u an additional pulley for the power steering but u have
to run the standard belt still. About $250 on Ebay. Gives ur motor that nice supercharged sound too. Just need to get those belts to li
CherryBomb Johnston Offline
#5 Posted : Friday, 31 October 2008 5:50:38 AM(UTC)
CherryBomb Johnston
An idea.
Wip into supa cheap auto, grab a V8 water pump box and look at what models and year that particular pump suits up too?
If the say, Black motors (VL) not listed for that pump. Pull one out, pull one of the other pumps out of there boxes and eye
"Because stock sucks"
HotRodder Offline
#6 Posted : Sunday, 2 November 2008 8:31:15 PM(UTC)
HotRodder
Are there any advantages to using this setup, I to have seen then on Ebay and have wondered about this.
jabba Offline
#7 Posted : Monday, 3 November 2008 8:23:26 PM(UTC)
jabba
Yes. The main advantage is that the belts do not suffer from slippage, and are less likely to suffer from "whip" and throwing themselves off.
If your "v" belts are not properly adjusted (or are behaving badly) then at high revs or sudden rev changes
Guest (5)
