Jampher Offline
#1 Posted : Friday, 14 March 2008 2:16:50 AM(UTC)
Jampher
is it possable to tell if a intake manifold on a 308 is a spread bore or not with out removing the carby, seieral numbers etc and do you need a spread bore maifold to run a 4 barrel carby? I was told you did and just resently i was told you didnt.
Moose
Moose
JBM Offline
#2 Posted : Friday, 14 March 2008 2:50:47 AM(UTC)
JBM
Holden 4 barrel manifolds are made to suit the Quad which has larger secondaries. Is that what you mean by spreadbore? I think squarebore has all four barrels the same size.
James
You only hav
#3 Posted : Friday, 14 March 2008 7:15:46 AM(UTC)
All original Holden manifolds are spreadbore.
