BAD WB Offline
#1 Posted : Sunday, 2 November 2008 11:27:47 PM(UTC)
BAD WB
Does any one know if the crank off a 350 chev SB will fit to a LT1 or will i need an actual lt1 crank?
#2 Posted : Monday, 3 November 2008 12:18:11 AM(UTC)
depends what LT1 you are using, late model with alloy water pump and 1 piece rear main or early type LT1 with steel heads??? early have different PCD on flexplate, and a host of different stuff.
BAD WB Offline
#3 Posted : Monday, 3 November 2008 6:57:48 AM(UTC)
BAD WB
alloy heads think off 94 corvette.
#4 Posted : Monday, 3 November 2008 7:16:33 PM(UTC)
yeah, yours will have the waterpump driven by the cam gear. they were prone to running bearings and trashing cranks and hurting themselves. you have to get crank from LT1 or similar era engine
adam PERTH Offline
#5 Posted : Tuesday, 4 November 2008 3:57:39 AM(UTC)
adam PERTH
Bad WB.
did you end up selling that blue 308?
WANTED:
QR 662xxx
1984 WB oyster crashpad
1x15x8 Cheviot armoulite HQ
pair of 15" Dragway centrelines suit HQ
BAD WB Offline
#6 Posted : Tuesday, 4 November 2008 8:27:51 AM(UTC)
BAD WB
still in the ute at the moment adam.
BAD WB Offline
#7 Posted : Tuesday, 4 November 2008 9:09:28 AM(UTC)
BAD WB
Was the bearing and Crank problems only with the 2 bolt blocks or was it a common problem with all blocks. Also after a rebuild this should sort out any issues with bearing and cranks Yeah???
#8 Posted : Wednesday, 5 November 2008 6:44:09 AM(UTC)
These LT1 engines powered Corvettes from 92-97 and where also an option for that generation of Camaro from 92-97. These engines suffered from many niggling issues such as over heating due to the water pump set up, knocking from big ends, low or no oil pre
Guest (5)
