asdf88 Offline
#1 Posted : Monday, 10 November 2008 7:58:57 AM(UTC)
asdf88
Hi Guys,
I have rebuilt a blue 202 engine rebored, new pistons, reco head, HV oil pump etc. Problem is that when i start it, there is a severe rattle for the first 20 - 30 seconds.
I have used a Z160 (VP V8) oil filter - the small one - in an effort to get quick oil pressure, but still the same.
Any ideas where the problem might be?
Thanks.
vintageholden Offline
#2 Posted : Monday, 10 November 2008 7:33:23 PM(UTC)
vintageholden
big ends,
did you rebuild it well???
Edited by user Monday, 10 November 2008 7:34:01 PM(UTC)  | Reason: Not specified
PISTOF Offline
#3 Posted : Monday, 10 November 2008 9:41:41 PM(UTC)
PISTOF
If your dip stick is the type with a thin bar near the bottom, check that the bar hasnt broken allowing the dipstick to hit the crank. Long shot but easy to check.
#4 Posted : Monday, 10 November 2008 11:04:15 PM(UTC)
Does it actually have oil pressure? Did you prime the oil pump with grease first? If not its probably time for another rebuild.
