HotRodder Offline
#1 Posted : Tuesday, 18 November 2008 10:25:32 AM(UTC)
HotRodder
Whats a good 9'' diff to use with a stock 302 windsor
and a C4 transmission, gear stuff that is.
#2 Posted : Wednesday, 19 November 2008 7:58:29 AM(UTC)
Depends if it is a daily driver, highway cruising, blasting off the line etc? 3.25 or 3.50 is generally a good all round ratio but there are a lot of things to consider. You will want a quiet set of gears set up right no matter what. A fresh LSD centre is
HotRodder Offline
#3 Posted : Thursday, 20 November 2008 11:20:48 AM(UTC)
HotRodder
Were a couple of old farts from the 60's so all we want it to be used as a cruiser.
Paul351xb Offline
#4 Posted : Thursday, 20 November 2008 11:27:10 PM(UTC)
Paul351xb
Then you don't really need a nine inch. A borgy diff out of a falcon should do the job. If you are still wanting the nine inch then about a 2.75 or 3.0 centre should give you a good cruiser. 3.0 a bit better off the start. 2.75 bit better highway spee
Edited by user Friday, 21 November 2008 3:05:25 AM(UTC)  | Reason: Not specified
78XC Offline
#5 Posted : Friday, 21 November 2008 7:45:11 AM(UTC)
78XC
I think you have to consider the average speed that you think you will be doing are you doing highway k's or suburb k's I agree with paul that 2.75 to 3.00 is good I would go more towards 2.7's better on fuel and longer legs.
