A mate just brought a 308 and TH350 for $300 sounds abit suss but just to make sure how can I ID it for him it might be a trimatic not that it matters just it would be good to know if it is or not it came out of a commodore but the eng# starts with QT so it cant original but the trans might still be commodore I need some words of wisdom thanx dudes
On The Other Hand There's Finger's |
Hey HZ DUDE this might help. A Tri-Matic can have left-hand or right-hand shifter, I think early Kingswoods and WBs are left-hand. TH350 & 400 left-hand only.
The shape of the oil pan is a dead giveaway. (TH350 vs 400 anyway). Cable kickdown right hand side, speedo connection left hand side towards the back. Vacuum modulator (little saucer shaped cannister thingy) right hand side rear.
____________________ |
__________________________________________ Keep the shiny side up, and the greasy side down. |
Trimatic has a removable bellhousing. With TH350/400 it is all part of the case. ID between TH boxes as above.
thanx dudes he has a trimatic cant winem all
On The Other Hand Theres Fingers |
Better than a TH350 in some ways anyway.
