kanks Offline
#1 Posted : Thursday, 20 November 2008 6:01:25 PM(UTC)
kanks
hi thinking of going big block t400 in hg has any one done this before .how hard is the enigineerig rego any tips cherrs
#2 Posted : Thursday, 20 November 2008 9:05:10 PM(UTC)
Looking at the same right now in a HK GTS, but not TH400 (Muncie).
Currently looking at front mounting a steering rack of unknown origin (UC Torana looks close), meaning swapping the stubs side to side. Yet to investigate if HK steering arms are OK or
monaro mark Offline
#3 Posted : Thursday, 20 November 2008 11:52:58 PM(UTC)
monaro mark
A guy on www.oldholden.com fitted a 454 into a HK premier but Im not sure what his username was. This is the car on youtube: http://au.youtube.com/watch?v=hkR7L6SRVGU
Mark
[email protected]
HQ GTS 4 Monaro 350, Auto, Mustard, Black
#4 Posted : Friday, 21 November 2008 12:00:56 AM(UTC)
#5 Posted : Friday, 21 November 2008 1:46:19 AM(UTC)
I need a manual rack, that is where the hassle is.
#6 Posted : Friday, 21 November 2008 2:09:31 AM(UTC)
Volvos were available sans power steering too and quite common and strong.
If at first you dont succeed then skydiving is not for you.
#7 Posted : Friday, 21 November 2008 2:44:39 AM(UTC)
#8 Posted : Friday, 21 November 2008 4:10:21 AM(UTC)
Because its basically being built the way Holden should have built them ie an L88 optioned HK GTS. I agree with you for Kanks HG though as it will probably see more road use than mine. Im just considering modernising the theme a tiny bit with Hoppers brak
#9 Posted : Friday, 21 November 2008 4:31:30 AM(UTC)
if you dont want the hassel of power stearing pumps hear is a simpel way to make power stearing. tye some large fishing sinckers to your stearing wheel as showen
#10 Posted : Friday, 21 November 2008 6:17:29 AM(UTC)
you guys are all making it hard. its any easier than seems fit, check out hugo @ raceglides car, he has a BBC in blue HK GTS looks factory, no hole in bonnet, no radical cuts
This page was generated in 0.151 seconds.
