hi thinking of going big block t400 in hg has any one done this before .how hard is the enigineerig rego any tips cherrs
Looking at the same right now in a HK GTS, but not TH400 (Muncie).
Currently looking at front mounting a steering rack of unknown origin (UC Torana looks close), meaning swapping the stubs side to side. Yet to investigate if HK steering arms are OK or |
A guy on www.oldholden.com fitted a 454 into a HK premier but Im not sure what his username was. This is the car on youtube: http://au.youtube.com/watch?v=hkR7L6SRVGU
Cheers Mark [email protected]--- HQ GTS 4 Monaro 350, Auto, Mustard, Black
quote: Originally posted by HK1837
Currently looking at front mounting a steering rack of unknown origin (UC Torana looks |
I need a manual rack, that is where the hassle is.
Volvos were available sans power steering too and quite common and strong.
If at first you dont succeed then skydiving is not for you. |
Because its basically being built the way Holden should have built them ie an L88 optioned HK GTS. I agree with you for Kanks HG though as it will probably see more road use than mine. Im just considering modernising the theme a tiny bit with Hoppers brak |
if you dont want the hassel of power stearing pumps hear is a simpel way to make power stearing. tye some large fishing sinckers to your stearing wheel as showen
you guys are all making it hard. its any easier than seems fit, check out hugo @ raceglides car, he has a BBC in blue HK GTS looks factory, no hole in bonnet, no radical cuts
