#1 Posted : Friday, 21 November 2008 2:59:02 AM(UTC)
hello i have a qestion about mixing paint for my hj pano i am trying to make metalic but it is coming out lumpy not little shiney bits. i am using ceiling white with glitter mixed in. how do i get it to look shiney do i need to sand it back after it drys? it is good qality paint berger and i have mixed in some blue i wanted it darker but it is more a pail blue. anyone can help just let me no thanks.
David Offline
#2 Posted : Friday, 21 November 2008 3:14:22 AM(UTC)
David
Is that the best you can come up with?
#3 Posted : Friday, 21 November 2008 3:36:28 AM(UTC)
hi david yes it is berger premium only better paint would proberly be dulux i think is that a lot better?
#4 Posted : Friday, 21 November 2008 6:00:02 AM(UTC)
No, Dulux is no good. It usually has lots of Dog hair in it and every now and again they mix jellybeans through it which gives a real lumpy look to your paint job. To make it shiny you need to put a couple of coats of Mr Sheen over it. Bettr buy a whole b
The Yeti Offline
#5 Posted : Friday, 21 November 2008 4:10:21 PM(UTC)
The Yeti
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
Big Al Offline
#6 Posted : Friday, 21 November 2008 9:24:10 PM(UTC)
Big Al
Also make sure you dont apply the paint upside down, because it will just come out very dull.
stevo280472 Offline
#7 Posted : Friday, 21 November 2008 10:35:08 PM(UTC)
stevo280472
Or inside out.
Go the Dragons!
Go the Dragons!
mmazz30 Offline
#8 Posted : Saturday, 22 November 2008 12:33:55 AM(UTC)
mmazz30
Make sure you use a wire brush for that metallic look that you are after.
#9 Posted : Sunday, 23 November 2008 2:38:23 AM(UTC)
try rectum rosebudd. its good for that stuff, get it from auto-shops
#10 Posted : Sunday, 23 November 2008 7:44:58 AM(UTC)
If you cant get hold of a spraygun, do not, and I stress, do not under any circumstances try to use a brush.
Go to bunnings & buy a roller.
You can even get these fancy little narrow ones now for doing the A-pillars.
________
vintageholden Offline
#11 Posted : Sunday, 23 November 2008 10:47:59 AM(UTC)
vintageholden
what a lot of worthless help..........
