hoarders Offline
#1 Posted : Friday, 21 November 2008 11:23:07 PM(UTC)
hoarders
I have a FJ Holden with a modified grey motor and 9.5 to 1 compression. It is converted to 12 volt electricals. I am having trouble getting a starter motor that is good enough to turn it over. Any suggestions?
m jones
m jones
#2 Posted : Saturday, 22 November 2008 8:33:01 PM(UTC)
Hi Hoarders , try posting this in general disscussion for mechanical questions cheers.
#3 Posted : Sunday, 23 November 2008 4:41:30 AM(UTC)
The stock starter motor should be good for around 13 to 1 compression mate, so the one you have may be on the way out?
#4 Posted : Sunday, 23 November 2008 8:36:30 AM(UTC)
12 volts should really crank it over and generally it will take 12 volts as long as you dont crank it over for too long at a time, and let it cool down. As blackie says maybe it needs a service.
#5 Posted : Sunday, 23 November 2008 8:36:30 AM(UTC)
12 volts should really crank it over and generally it will take 12 volts as long as you don't crank it over for too long at a time, and let it cool down. As blackie says maybe it needs a service.
#6 Posted : Monday, 24 November 2008 4:19:36 PM(UTC)
My warm 308 was the same, try new battery leads and a more powerfull battery.
