goldenholden Offline
#1 Posted : Saturday, 22 November 2008 6:37:29 PM(UTC)
goldenholden
i have a hq with a 186 and electic ignition that i replaced a few years ago, now it just stopped and wouldnt start. i took the electronic distributer out and the cog had been broken. i replaced it with a new one and it was going ok till the muffler blew apart after it back fired. i have since replaced the muffler and put the distributer back in but it won't stay running and it runs rough while it is going till it stops. i have no clue how to fix it and do'nt know what else to do. need help!
#2 Posted : Saturday, 22 November 2008 6:39:21 PM(UTC)
has it got petrel in it ?
#3 Posted : Saturday, 22 November 2008 6:42:44 PM(UTC)
also check the poynts and make sure the coil is not wired up backwoods
pont69 Offline
#4 Posted : Saturday, 22 November 2008 6:57:33 PM(UTC)
pont69
also, check might wanna check his spelling haha
umm check that your distributor hat insnt 180 degrees around, cos that way itll be trying to fire when its pushing exhaust..
hope that helps
Get your feral little mittens off it!
Cheers, James
#5 Posted : Saturday, 22 November 2008 6:59:28 PM(UTC)
If its had a big backfire, it may now have vacuum leaks which could cause your symtoms.
#6 Posted : Saturday, 22 November 2008 7:04:37 PM(UTC)
also check for earths this means if you have any dirt on the wires you should clean it off so the power can get in
trubluhq Offline
#7 Posted : Saturday, 22 November 2008 7:43:55 PM(UTC)
trubluhq
If it was working with a 2nd electronic dizzy, why did u put the HQ one back in after the muffler blew ?
The way this reads I would put the electronic dizzy back in. That worked so u said. Otherwise, put the HQ point dizzy back in, hook up the dizzy ad
#8 Posted : Saturday, 22 November 2008 8:16:20 PM(UTC)
If you had a backfire BIG enough to blow your muffler apart your timing was wrong and now carby is now also suspect .That much pressure back there,imagine the inside of your carby now!ps return it to its last know good configuration!..(lol)..and before yo
#9 Posted : Sunday, 23 November 2008 12:50:31 AM(UTC)
i hope its not likr the other guy and put too much water in the fuel tank.
#10 Posted : Sunday, 23 November 2008 8:30:31 AM(UTC)
goldenholden
haha, lol. yer it has a half a tank!
#11 Posted : Sunday, 23 November 2008 8:32:13 AM(UTC)
goldenholden
it doesnt have points, its electric
#12 Posted : Sunday, 23 November 2008 8:37:51 AM(UTC)
goldenholden
could the distributior have moved and thats whats causeing it because it was running perfect before i had to take it out and put a new cog in it and since then it hasnt been running and it doesnt start or if i get it started it runs then just stops
#13 Posted : Sunday, 23 November 2008 8:44:48 AM(UTC)
goldenholden
it hasnt had a points dizzy for a few years its still electric. the muffler blew apart after i took the dizzy out to replace the cog that had broke and when i put it back in it wouldnt start , when it was driveable and ok the muffler blew and lost a lot o
#14 Posted : Wednesday, 26 November 2008 2:42:38 AM(UTC)
what about the low volage wire. the dizzy may not be getting the full 12 volts it needs. or could it be the module that sits at the base of the dizzy breaking down.
