#1 Posted : Saturday, 22 November 2008 9:29:49 PM(UTC)
hi all,
i have noticed a whirring noise coming from the diff while driving. this only happens when i back off the accelerator. under exceleration its fine. is this a major problem? can it be easily fixed and for how much?
im driving a hz 1 tonner
thanks for any info
#2 Posted : Saturday, 22 November 2008 9:35:27 PM(UTC)
hi a mechanic should be abel to fix it
toranaguy Offline
#3 Posted : Wednesday, 26 November 2008 9:48:04 AM(UTC)
toranaguy
I had the same problem with my Torana. I ended up picking up a 2nd hand diff for $50, cleaning it out, replacing all the bearings and swapped some of the parts from my diff in to the new 1. All up only cost round $200. Replaced the diff myself with a mate
Edited by user Wednesday, 26 November 2008 9:52:38 AM(UTC)  | Reason: Not specified
#4 Posted : Wednesday, 26 November 2008 11:20:09 AM(UTC)
Sounds like worn pinion bearings to me.
#5 Posted : Thursday, 27 November 2008 6:05:04 PM(UTC)
Greetings,
There will be a diagnosis section in the service manual with a checklist to identify the noise you mention. Many things can contribute noises in a car. The diff noise as you call it must be loud if you can hear it driving a 1 tonner.
