David Offline
#1 Posted : Tuesday, 25 November 2008 7:43:21 AM(UTC)
David
Hi Fellas,
My son is building a bush basher. It will be powered by a motor bike engine, therefore will be chain driven. He wants to use parts from a Calibra to build the drive chain.
He wants to join together the shafts that come from the diff to make a single rear axle, and weld on a sprocket. The CV joints will allow movement for the suspension, and he can use the disc brakes.
Can the shafts be welded? Who does this type of work? What sort of cost? Could I do it myself, or would the temper be destroyed?
All advice is appreciated.
David
basketcasebear Offline
#2 Posted : Tuesday, 25 November 2008 7:56:47 AM(UTC)
basketcasebear
hey david,
i am sure i understand what you are trying to acheive,
i am not sure as to whether the drive shafts are tempered or not?
i am sure you could ring someone who repairs drive shafts??
might be advantages to make your sprocket with a sleeve in
DOH!!!
playwme Offline
#3 Posted : Tuesday, 25 November 2008 8:26:54 AM(UTC)
playwme
How is the centre of the "axle" going to be supported? In an independant suspension setup the diff centre (or in this case the centre section containing the sprocket) is bolted solid to the body of the vehicle. Instead of welding the 2 together he would b
mrhqute Offline
#4 Posted : Tuesday, 25 November 2008 9:17:48 AM(UTC)
mrhqute
How wide is it going to be? Im guessing you would want to cut the axles to narrow the width a bit.
Ross
#5 Posted : Tuesday, 25 November 2008 10:27:08 AM(UTC)
basketcasebear
it sounds like something similiar to a gocart?
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!"
and the wind did not answer, it just laughed in space.
k.g/
DOH!!!
David Offline
#6 Posted : Wednesday, 26 November 2008 9:31:09 AM(UTC)
David
Thanks for comments fellas. Some good advice in there! These bits ring true to me:
I am sure you could ring someone who repairs drive shafts??
might be advantages to make your sprocket with a sleeve in the centre, then connect drive shafts into this??
