HotRodder Offline
#1 Posted : Tuesday, 25 November 2008 10:35:05 AM(UTC)
HotRodder
Just wondering if there is any advantages using a
billet steel gear drive over the original chain drive.
The Yeti Offline
#2 Posted : Tuesday, 25 November 2008 4:12:58 PM(UTC)
The Yeti
on the street no, although they sound cool
See The Yetis Chev build at
http://www.ozrodders.com...rd/viewtopic.php?t=17919
Macquarie Towns Hot Rod Clubs new website http://www.hotrodclub.info
See The Yeti's Chev build at
jabba Offline
#3 Posted : Tuesday, 25 November 2008 5:11:56 PM(UTC)
jabba
My engine builder and I have just had this discussion. His take is that they are a huge waste of time effort energy and expense. It is unusual to have them bolt straight in, they are a bugger to set up and dont really do that much.
Unless you are goin
Luke in SA Offline
#4 Posted : Tuesday, 25 November 2008 5:14:53 PM(UTC)
Luke in SA
As the Yeti said -
On the Street N0 - But they sound cooler than cool.
#5 Posted : Wednesday, 26 November 2008 2:32:19 AM(UTC)
there was a LH 308 Torana not far from here that has the gear drive. he just put them in. really noisey and they rattle around really bad. now he has to get a timing case as the teeth have worn thru the cover and sprayed oil everywhere. then i have seen t
Intoit Offline
#6 Posted : Wednesday, 26 November 2008 4:34:34 AM(UTC)
Intoit
Had one in my Torrie, as Luke said, they sound cool, no good for high rev applications though, cant get enough lubrication to it. I ended up breaking the circlips on the idler gears from revving it too hard.
--------------------Go Hard Or Go Home
Sandman Offline
#7 Posted : Wednesday, 26 November 2008 8:59:28 AM(UTC)
Sandman
Ive got one on one of my engines. It took a lot of work to get the clearance on the gears set up. (I run them at .002") but its so quiet the you wouldnt even notice it. If you run the gears loose then they will be noisy.
I onl got it to be able to change
HotRodder Offline
#8 Posted : Sunday, 30 November 2008 11:30:24 AM(UTC)
HotRodder
Thanks guys, the chains the way to go if I ever have a
Holden engine again.
Guest (7)
