#1 Posted : Sunday, 30 November 2008 3:19:17 AM(UTC)
WANT TO BUY A QR NUMBERED 253 FROM A HQ WITH A BLOCK BUILD DATE
OF K,L,M 2 (LATE 1972) OR A,B,C 3 (EARLY 1973)
Call Chris 0411877168
#2 Posted : Sunday, 30 November 2008 8:13:17 AM(UTC)
Was thanked: 632 time(s) in 594 post(s)
Theres a Hxx2 block on Ebay at the moment. I think it's QR2xxxxx. Search under Bathurst 253. Not sure why he put that in but that is what it says.
If we all had the same (good) taste, who would b
#3 Posted : Sunday, 30 November 2008 8:13:17 AM(UTC)
Theres a Hxx2 block on Ebay at the moment. I think its QR2xxxxx. Search under Bathurst 253. Not sure why he put that in but that is what it says.
If we all had the same (good) taste, who would bu
#4 Posted : Sunday, 30 November 2008 8:51:02 AM(UTC)
Its here
http://cgi.ebay.com.au/w...WAX:IT&item=280288462786
H152 so 15th 8th 72 block engine number QR2143XX
so may be to early for the above poster.
#5 Posted : Sunday, 30 November 2008 10:01:13 AM(UTC)
Thanks for the info but i am a little confused why do some engine build dates like the one above start with a letter then numbers
eg H152 and others have the letter in the middle eg 13J3, yet they are both for HQ and both have QR engine numbers ?
#6 Posted : Sunday, 30 November 2008 9:43:43 PM(UTC)
There was a early date code system, month-day-year H152(like chevs) and then it changed to a later system, day-month-year 13J3
From the few records I have at that time it seems to have happened around May-June 1973.
This is with engine blocks at least,
#7 Posted : Monday, 1 December 2008 7:30:42 AM(UTC)
On HK only the US GM parts like diff, engine, block etc use the US system. Other stuff seems to be the Aussie way. Not sure why Holden cast their early blocks using the US style date code.
If we
#8 Posted : Tuesday, 2 December 2008 6:49:21 AM(UTC)
HK1837. On HQ would that be the same as HK in relation to the coding.
So from what you have posted, I have wrongly assumed that all parts had a early and a late system.
I thought because I have Engine blocks, valley's, exhaust manifolds, heads, gearbox'
#9 Posted : Tuesday, 2 December 2008 6:49:21 AM(UTC)
I thought because I have Engine blocks, valleys, exhaust manifolds, heads, gearboxs,
#10 Posted : Wednesday, 3 December 2008 6:14:13 AM(UTC)
It would be logical to assume what you did. But it doesnt appear to work that way with everything. HK-HG certainly have some parts with Aussie style date codes like steering boxes, crossmember, steering column etc. I always assumed it was only the North A
#11 Posted : Wednesday, 3 December 2008 6:14:13 AM(UTC)
It would be logical to assume what you did. But it doesn't appear to work that way with everything. HK-HG certainly have some parts with Aussie style date codes like steering boxes, crossmember, steering column etc. I always assumed it was only the North
Clawd Offline
#12 Posted : Wednesday, 3 December 2008 6:54:34 AM(UTC)
Clawd
Hey Chris,
I have a complete engine with cast code of G243 and engine number QR 32xxxx. This should make it a july 24 1973.
Clawd
HG Monaros for ever!
#13 Posted : Wednesday, 3 December 2008 8:17:53 AM(UTC)
HK1837 Rather than totally taking this advert over (sorry Chris).
I have started this
http://www.fastlane.com....topic.asp?TOPIC_ID=19181
in the correct area.
Cheers Paul.
#14 Posted : Friday, 12 December 2008 8:42:26 AM(UTC)
Thanks Claude for the offer but i really need an early 73 253 motor Jan,Feb or March.
Ta
#15 Posted : Thursday, 8 January 2009 8:58:04 AM(UTC)
Still looking for that elusive 253 with QR engine number and A,B,C,3
block build date !!!
Guest (5)
This page was generated in 0.083 seconds.
