musksell Offline
#1 Posted : Tuesday, 2 December 2008 7:55:02 AM(UTC)
musksell
if Im standing at radiator looking at Carb there are two small screws on bottom plate....which one is for idle and which one is for mixture and which way to you screw them....if I've got this correct so far....
thanks
RB
#2 Posted : Tuesday, 2 December 2008 8:47:58 AM(UTC)
Both are mixture.
In is lean, out is rich.
Screw them both in gently till they seat then out 1-1/4 to 1-1/2 turns.
Start engine and tune from there.
Turn them in/out equal amounts.
Idle speed adjusting screw has a coil spring on it and is near wher
74HJLS Offline
#3 Posted : Tuesday, 2 December 2008 7:12:00 PM(UTC)
74HJLS
You were kind of half right with both, they both are for idle mixture.
Pete.
Pete.
adam PERTH Offline
#4 Posted : Friday, 5 December 2008 4:01:55 AM(UTC)
adam PERTH
cup your hands over the carb at idle.
if the revs pick up slightly, you have the mixture about right.
WANTED:
QR 662xxx
1984 WB oyster crashpad
1x15x8 Cheviot armoulite HQ
pair of 15" Dragway centrelines suit HQ
musksell Offline
#5 Posted : Friday, 5 December 2008 6:53:29 AM(UTC)
musksell
thats a good idea......and so easy to do... cheers...
Guest (6)
