VK 308 roughly 200rwhp what would be the best carby to suit this rig. HQ FOR SALE!!! http://www.tradingpost.c...691635?BackToResult=true
Rochester Q-Jet. get one that starts with 17xxx part number (1976 + up) ideally 1708xxx (late 1979 + up)
Eagle auto spares do AC Delco built reco ones for around $330 delivered.
WANTED: QR 662xxx 1984 WB oyster crashpad 1x15x8 Cheviot armouli |
probably have to get one ex perth. not enough time for east...it not for me it for a mates daily driver.... 650 square bore double pumper be good for it???? HQ FOR SALE!!! http://www.tradingpost.c...que-Cars/Hot-Custom-Stre
What Adam said.
just put one on my HZ work ute.....made a big diifference even on gas ....because idle was all over the place.....didnt take any notice of numbers though......maybe I should of asked here...?
Rebuilt at Melb carbs Unit 6 12-20 James court Tottenham C
Hi
I got a reconditioned Rochester from Melb Carbs couple of months ago. I ordered it over the phone and it came next day by express post.
Good value too.
Mark
I am not allowed a mistress so i got a GTS - and its better |
A GTS/4 is a monaro - so nuuur |
Should have said i am in Perth too.
any one have a rochester ??? i have holley 500cfm on my 308 wb not the best carby what about 390 cfm or 465 small 4brl
iv asked the question to over 10 mechanics/carby places/performance shops....each one has said something different.... HQ FOR SALE!!! http://www.tradingpost.c...ber=TP000691635?BackToRe
I have a 253 and am thinking of putting the edelbrock performer manifold with a Holley 600cfm. Im not a mechanic so would something like this be ok for a 253 red motor.
Edelbrock Performer manifold is a good choice, but sell the 600 Holley and use a Quadrajet off a blue 253. If your 253 is an early one (pre HX) use a HT-HJ 308 manifold. It will work as well as the Edelbrock.
___________________________________________ |
thanks for the advise HK1837. Where would i be able to find a good Quadrajet from.
Anyone that wrecks VC-VH Commodores or WBs. You can use a 308 one from a VK or VL, it will just need the primary needles and a few other bits changed. Try Greg at ClassicOzWreck 02 49598999. Hed probably have one, but more likely to have a 308 one. Get it |
http://www.hume.com.au/i...b52d1b2a265b588990da896
Thanks mate. So would the RR601A Rochester Quad - Aust.601 would fit straight onto the edelbrock manifold no problems. How come these are better than buying a new Holl
603A is the better carby as you can adjust the primary metering rods without pulling the carby apart and they have an integral choke also. The 601A is for use on the pre HX manifold where the choke operator is on the manifold.
