YetAnotherForum.NET Help
#1 Posted : Sunday, 7 December 2008 6:05:52 PM(UTC)
i want to change my lj from aussie 4 speed to trimatic,
can anyone please tell me if the gearbox cross member is the same?
JBM Offline
#2 Posted : Sunday, 7 December 2008 7:27:43 PM(UTC)
JBM
I was going to do the opposite on my VH and was told that the cross member and tailshaft didnt need changing.
Hope this helps.
James
bundybluedog Offline
#3 Posted : Sunday, 7 December 2008 8:19:16 PM(UTC)
bundybluedog
they are the same.
#4 Posted : Sunday, 7 December 2008 8:21:35 PM(UTC)
cheers guys,i already have a trimatic tailshaft to :)
#5 Posted : Monday, 8 December 2008 6:53:46 AM(UTC)
bundybluedog
were are you at i have an LC im thinking of putting a manual will swap you pedals if you want. north brisbane
JBM Offline
#6 Posted : Monday, 8 December 2008 8:59:21 AM(UTC)
JBM
The speedo cable was also the same.
James
74HJLS Offline
#7 Posted : Monday, 8 December 2008 2:17:48 PM(UTC)
74HJLS
Tailshaft is the same too.
Pete.
Pete.
pont69 Offline
#8 Posted : Tuesday, 9 December 2008 6:56:02 AM(UTC)
pont69
the entire lot is identical.
i swapped my trimatic out (still sitting here) for the m21 4 speed.
just needed longer bolts for the flywheel as its thicker than the flex plate
Get your feral little mittens off it!
Cheers, James
#9 Posted : Tuesday, 9 December 2008 7:29:01 AM(UTC)
Crossmembers are different if I remember correctly, but they can be interchanged. I know LH-UC are different between trimatic and aussie manual boxes - the manual bolts hard up to the body with holes just the right size for the bolts, but the auto has big
Rutcho Offline
#10 Posted : Wednesday, 10 December 2008 6:23:28 AM(UTC)
Rutcho
hi sorry if this is a stupid question but are there specific models of trimatics or will they all fit in my HG ?
#11 Posted : Wednesday, 10 December 2008 7:07:49 AM(UTC)
Discounting the difference between 6cyl and V8 there are three basic types:
HT/HG - cable kickdown, LH shift for T-bar, RH shift for column;
HQ-WB, LH-LX, and UC column (and LC/LJ I think) - electric kickdown, RH shift;
VB-VL and UC T-bar - electric
Rutcho Offline
#12 Posted : Sunday, 14 December 2008 8:04:05 PM(UTC)
Rutcho
so i can only put the HT/HG cable kick down in it?.will it bolt straight on with same cross member and can you give me a quick rundown on how the kickdown works ? sorry to be a pain but i have to know. thanks
#13 Posted : Sunday, 14 December 2008 11:41:55 PM(UTC)
Any trimatic will fit, making sure you get the shift side you want. Only problem is HT/G dont have the facility for an electric kickdown switch standard. Youll have to adapt something to the accelerator linkage somewhere. Have a look up under the dash at
Rutcho Offline
#14 Posted : Monday, 15 December 2008 7:31:50 AM(UTC)
Rutcho
thanks for your help im getting some great info from this web site
Rutcho Offline
#15 Posted : Tuesday, 16 December 2008 6:48:10 AM(UTC)
Rutcho
some one told me i will have to change the pedals is that true ? any help appriciated
#16 Posted : Tuesday, 16 December 2008 6:58:41 AM(UTC)
To be perfectly correct youll need to fit the bigger auto pedal, but I prefer to use a manual pedal and remove the clutch pedal. Makes for more room.
If we all had the same (good) taste, who woul
Guest (9)
This page was generated in 0.121 seconds.
