bundybluedog Offline
#1 Posted : Tuesday, 9 December 2008 7:09:21 AM(UTC)
bundybluedog
will a roller cams out perform a solid flat tappet? if so can anyone tell me why? whats the diferance between a holden roller block and the normal 5 litre blocks?
Dan
#2 Posted : Tuesday, 9 December 2008 7:24:00 AM(UTC)
Yes. Roller cam has steeper ramps and allows valves to open/close much quicker. VSIII and VT sequential block has bosses to mount the roller cradle from memory.
If we all had the same (good) tast
#3 Posted : Tuesday, 9 December 2008 7:32:04 AM(UTC)
bundybluedog
so can you fit a roller cam to a VN 5 litre block?
#4 Posted : Tuesday, 9 December 2008 4:28:13 PM(UTC)
You probably can, but youd be best off talking to Comp Cams or Crane. Crane list some roller cams for the pre VN engines so if one will fit them I assume you can fit one to a VN (albeit different valve arrangement).
____________________________________
Tex Scrotum rides again Offline
#5 Posted : Tuesday, 9 December 2008 11:59:37 PM(UTC)
Like HK1837 said,a roller cam will have the valve off its seat quicker and have the valve open longer at a higher lift than a solid cam.
So if you had a roller and a solid(or hydraulic)with both the same duration and lift,the roller would(should) out
