kraul Offline
#1 Posted : Monday, 15 December 2008 11:40:24 PM(UTC)
kraul
iv got a wb ute runing a blue 202 but i want to do it up and put a nice reliable engine into it to go with the body restoration. Im not after huge power as this wil be my daily. Any recomendations for whats easy to fit and easy to get for a transplant?
Tex Scrotum rides again Offline
#2 Posted : Tuesday, 16 December 2008 12:02:00 AM(UTC)
Hard to go past the OLLLe small block chevy,best bang for buck and theres about 9 million of em out there.........
#3 Posted : Tuesday, 16 December 2008 12:47:43 AM(UTC)
Edited by user Tuesday, 16 December 2008 1:12:51 AM(UTC)  | Reason: Not specified
kraul Offline
#4 Posted : Tuesday, 16 December 2008 12:57:42 AM(UTC)
kraul
i can get a old blue 308 with manual 4speed for $500 but it needs a recon. But thats not hard. Is that a reasonable price. I was thinking an rb30 at one point but they would be hard to licence aswell i guess.
#5 Posted : Tuesday, 16 December 2008 1:02:12 AM(UTC)
a complete 308 with 4 spd is a good buy for $500. and an easy conversion.
#6 Posted : Tuesday, 16 December 2008 1:05:47 AM(UTC)
a wb ute is not so light with a full chassis so the nissan motor wont perform as it would in a VL. if you wanted to go to the trouble go for a V6 .
kraul Offline
#7 Posted : Tuesday, 16 December 2008 1:41:09 AM(UTC)
kraul
nah im not a fan of the v6. I think the 308 would be beter. I should be able to get 200hp easily right?
#8 Posted : Tuesday, 16 December 2008 2:21:39 AM(UTC)
The early red 308 HQ-HJ was 240-250 bhp from factory, plenty for a daily driver, as you said you are not looking for huge power.If you have to re-con a 308 maybe stick a mild cam in it, 1 or 2 up from standard , elec dizzy (which the blue should have alre
kraul Offline
#9 Posted : Tuesday, 16 December 2008 3:08:03 AM(UTC)
kraul
yeah fuel economy would be nice. My other car isnt so gud but its got the power. Thats why i want a nice daily. A tidy 308 sounds good and easy to register. Cheers for your help.
#10 Posted : Tuesday, 16 December 2008 3:40:28 AM(UTC)
What about a stroker kit for the 308?
If it needs a reco then buy the time you get new pistons,rings etc and maybe even reco the crank,you might be able to buy one of the cheapo stroker kits out there!
Easy low down grunt and no-one has to know.....
kraul Offline
#11 Posted : Tuesday, 16 December 2008 3:42:17 AM(UTC)
kraul
that may be sumthing worth looking into.
#12 Posted : Tuesday, 16 December 2008 3:57:11 AM(UTC)
The M20 will know!
kraul Offline
#13 Posted : Tuesday, 16 December 2008 4:30:44 AM(UTC)
kraul
wel reliability is a key factor. So would a supra 5speed or sumthing be a beter option?
#14 Posted : Tuesday, 16 December 2008 4:37:26 AM(UTC)
Tremec.....but now its starting to get a bit pricey!
kraul Offline
#15 Posted : Tuesday, 16 December 2008 4:40:44 AM(UTC)
kraul
yeah i dunt want to get to pricy realy. Stil gota show both cars love lol. So maybe not a stroker kit then
musksell Offline
#16 Posted : Tuesday, 16 December 2008 6:04:55 AM(UTC)
musksell
The easiest way would be to put a VK fuel injected 202 in, these were rated at 100kw as against 80kw for your carb 202.
The fact you already have got a 202 in there makes it a easy transfer.
There was a good runner at kingswood country Vic for $450.
kraul Offline
#17 Posted : Tuesday, 16 December 2008 6:36:39 AM(UTC)
kraul
im looking to change from the 202. I didnt mention it but it already is the efi 202. I just dont particulary like it. Thats why i was looking for sumthing else. A fresh 308 with good exhaust and carby intake combo will be enough for me i hope. Aslong as t
#18 Posted : Tuesday, 16 December 2008 6:47:41 AM(UTC)
Id buy that blue 308 and aussie 4spd. Rebuild both. For the 308 I suggest a good basic build as:
Get it up to 9.5:1 compression if you have access to 95 or 98 Octane and run a mild cam with a bit of overlap to lower the compression slightly.
Get the h
kraul Offline
#19 Posted : Tuesday, 16 December 2008 7:42:32 AM(UTC)
kraul
ok. That sounds the go. Since the v8 going to be heavier il have to with heavier springs and upgrade the brakes i take it. Anything else that iv mised?
petaus Offline
#20 Posted : Tuesday, 16 December 2008 8:20:08 AM(UTC)
petaus
i think there was over 55 million small block,s made end to end 4 times to moon and back even maccas would be impressed with numbers like that, it,s also said it,s won the most races
