2 Pages<12
#21 Posted : Tuesday, 16 December 2008 4:19:54 PM(UTC)
Brakes are the same. 1-2 inch lowered V8 front springs will be all you need.
Also forgot, youll need a V8 WB 3 row radiator and shroud. If the blue 308 doesnt have the square blade original fan on it you can get one of those off any 5 litre from 1980 WB
kraul Offline
#22 Posted : Tuesday, 16 December 2008 9:31:52 PM(UTC)
kraul
iv already got the 3core radiator so thats set and its a m20 cable set up in the ute atm for the box. so springs diff and tailshaft. since i do a fair bit of highway driving and the final ratio of the m21 and m20 is 1:1 3.08 is the ratio im looking at.
#23 Posted : Tuesday, 16 December 2008 10:05:00 PM(UTC)
WB 6cyl 3 row is no good to you. Youll need a V8 one.
Hopefully the box you are looking at is an M20, as an M21 with a 3.08 with tall tyres in a heavy ute isnt much fun in 1st. If you already have an M20, Id just buy a new V8 input shaft and shaft cover
kraul Offline
#24 Posted : Tuesday, 16 December 2008 11:17:28 PM(UTC)
kraul
it is a v8 3core im prety sure. It was a pain to get. Ok m20 is the go. Thats whats with the 6 atm so i litle freshen up plus the v8 input shaft should be al it needs unles its stufd inside. Iv never looked.
munro73 Offline
#25 Posted : Wednesday, 17 December 2008 11:06:48 AM(UTC)
munro73
hate to disapoint u mate but v8 radatiors have different hose outputs
youll either have to modify yours or buy the v8 style
marge pass me my gun
kraul Offline
#26 Posted : Wednesday, 17 December 2008 6:52:15 PM(UTC)
kraul
it used to be a 2core looking at the radiator from the front of the car the inlet is on the top right and the outlet is the bottom left. Which one is this?
munro73 Offline
#27 Posted : Friday, 19 December 2008 5:43:01 AM(UTC)
munro73
reveresed on the 6s like i said modify or replace
not hard chances are theyve modifyed yours to fit
munro73 Offline
#28 Posted : Friday, 19 December 2008 5:44:03 AM(UTC)
munro73
sorry yours is a 6 cly m8t
cheezel308 Offline
#29 Posted : Saturday, 20 December 2008 7:21:23 PM(UTC)
cheezel308
never be late in a 308
Luke in SA Offline
#30 Posted : Sunday, 21 December 2008 9:30:25 PM(UTC)
Luke in SA
Yup, If you go down the path of rebuilding a blue 308 then throw in a SCAT stroker crank and rods while its apart. Then you have 350 cubes just like a Chev without the rego hassle.
Very Simple Job. Not much of a difference in cost.
Guest (12)
2 Pages<12
