Davesmonaro68 Offline
#1 Posted : Monday, 22 December 2008 8:20:14 PM(UTC)
Davesmonaro68
Hey guys what needs to be done to put an aussie 4speed to a ecotec v6 or do they bolt straight up.
Dave
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#2 Posted : Monday, 22 December 2008 11:00:57 PM(UTC)
Are you sure you want to do this, the V6 is pretty powerful and is likely to destroy the M20. If you are then they are a turbo pattern block, so you will need the chevrolet pattern to Aussie 4 speed delow belhousing. Not sure about clutch and pressure pla
#3 Posted : Tuesday, 23 December 2008 12:05:54 AM(UTC)
The V6 bolt pattern is actually quite different to SBC or Holden 6 or V8. It uses the old Buick V6 pattern.
As Warren said, are you sure you want to do this.
Dr Terry.
#4 Posted : Tuesday, 23 December 2008 6:14:28 AM(UTC)
Davesmonaro68
Its for a speedway car only uses 1st and 2nd. Most racers use three speeds or even single rail boxes , i have many holden 4 speeds in my collection (or Junk) just wanted to use some of these without having to buy a 5speed.
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
#5 Posted : Tuesday, 23 December 2008 7:18:04 AM(UTC)
Ill ask a workmate tomorrow what he uses - he has 2 cars running 3800 V6s.
FastEHHolden Offline
#6 Posted : Tuesday, 23 December 2008 7:57:42 AM(UTC)
FastEHHolden
Then I would get a stuffed Turbo 700 and cut the bellhousing off, mate that to the flange off an aussie 4 bellhousing...but there will be a fair bit of measuring....Im pretty sure a T5 pressure plate with work with the aussie 4 disc...they are close for s
#7 Posted : Wednesday, 24 December 2008 12:58:14 PM(UTC)
the spigot end of the input shaft is smaller on a aussie 4speed than a t5
Guest (7)
