dede Offline
#1 Posted : Tuesday, 23 December 2008 12:49:04 AM(UTC)
dede
Got 78 Marquis. Very nasty vibration from back end. Tried new wheels, tyres, (15 different combinations), tailshaft rebuild and balance, gearbox rebuilt, 14 point suspension check, new right rear axle, engine mounts all tightened...could go on but won't!, Mechanics have had for four months and can't find problem. Only happens when going over 90 kph. Can anyone suggest? Love car so much but shakes the eyeballs out of my skull!
#2 Posted : Tuesday, 23 December 2008 12:55:05 AM(UTC)
How do you know it is coming from the back end?
munro73 Offline
#3 Posted : Tuesday, 23 December 2008 8:57:25 AM(UTC)
munro73
might b a long shot but check your harmonic balancer
marge pass me my gun
XB351 Offline
#4 Posted : Tuesday, 23 December 2008 6:29:26 PM(UTC)
XB351
A couple of q's.
Does it have a 9" diff?
Check the housing isn't bent. They do twist quite easily unless they're well braced.
Is you car lowered?
How does the pinion angle look at the diff and gearbox. There should be no more than around 3 de
dede Offline
#5 Posted : Tuesday, 23 December 2008 10:01:04 PM(UTC)
dede
Hi, Dede again.
Thanks so much for your interest and answers. Will take it all on board and let you know how I get on in new year. Have a good one.
It does have 9 inch dif, it's lowered but not with blocks and the rest I'll have to check out with
Edited by user Tuesday, 23 December 2008 10:07:08 PM(UTC)  | Reason: Not specified
snappa Offline
#6 Posted : Friday, 2 January 2009 12:47:38 PM(UTC)
snappa
GIDDAY DEDE, HOW DID YOU GO WITH YOUR PROBLEM?
351 ZH
351 ZH
Guest (5)
