marksg62 Offline
#1 Posted : Tuesday, 23 December 2008 5:40:45 PM(UTC)
marksg62
Having a problem lining up rear mount on a HG ute.Engine mounts are new and correct sides fitted.also a new hadfield g/box x/member,Extension housing hits on the top LHS bolt on the floor brace.Its possible to move to the right but the lower g/box mount is then off centre.I have had the front crossmember rebuilt with all new bushes and pads etc,is it possible it can be misaligned??I was to understand V8 and 6 front crossmembers are the same,is this correct?? help appreciated.
#2 Posted : Wednesday, 24 December 2008 3:26:55 AM(UTC)
Mark pardon for not taking the time to log in. Have you seen an auto or saginaw gearbox crossmember they have the top cut out where the mount sits and a plate welded to the bottom so that the trans mount now sits lower by probably 1 inch, I have never fit
