hatchssv8 Offline
#1 Posted : Wednesday, 24 December 2008 3:22:30 AM(UTC)
hatchssv8
One set of 8 pistons/pins/rings for a 308 to 355 stroker
Still in its original box, never fitted to rods. They are +020.
ACL p/n 8MKRY9571 020
open to genuine offers 0418398756
hztonner Offline
#2 Posted : Wednesday, 24 December 2008 9:00:03 AM(UTC)
hztonner
how much thanks
old fart racing the older i get the faster i was
hatchssv8 Offline
#3 Posted : Wednesday, 24 December 2008 11:14:14 AM(UTC)
hatchssv8
OK
how does 600 sound?
This should at least get the ball rolling
#4 Posted : Monday, 29 December 2008 9:19:47 AM(UTC)
How about $500 does that seem more realistic?
The cheapest I could price them was $735
Luke in SA Offline
#5 Posted : Tuesday, 30 December 2008 12:30:36 AM(UTC)
Luke in SA
To suit Holden (5.627 inch)or Chev (5.7 or 6 inch) Connnecting Rod ??
Luke in SA Offline
#6 Posted : Tuesday, 30 December 2008 12:34:17 AM(UTC)
Luke in SA
#7 Posted : Wednesday, 31 December 2008 6:41:32 AM(UTC)
Was thanked: 632 time(s) in 594 post(s)
They are "low" compression to suit a 304/308 block, standard deck with Holden rods and 3.48" stroke crank. At +0.020" will give you about 353 cubes. By "low" comp I mean about 8.8:1 with I assume standard VN heads. Good stuff if you want a tough street mo
hatchssv8 Offline
#8 Posted : Wednesday, 31 December 2008 7:32:51 AM(UTC)
hatchssv8
Thats the beauty of these. You get the best of both worlds if you want. HSV stock heads, mild cam and these slugs put out 220kw. Or if you put a bigger cam (apart from OE restorers, who puts in stock cams these days) mild headwork, exhaust and these pist
Guest (6)
