One set of 8 pistons/pins/rings for a 308 to 355 stroker Still in its original box, never fitted to rods. They are +020. ACL p/n 8MKRY9571 020     open to genuine offers 0418398756
how much thanks
old fart racing the older i get the faster i was |
OK
how does 600 sound?
This should at least get the ball rolling
You are a member of these groups:: Guests
How about $500 does that seem more realistic?
The cheapest I could price them was $735
To suit Holden (5.627 inch)or Chev (5.7 or 6 inch) Connnecting Rod ??
Thanks: 1 times Was thanked: 632 time(s) in 594 post(s)
They are "low" compression to suit a 304/308 block, standard deck with Holden rods and 3.48" stroke crank. At +0.020" will give you about 353 cubes. By "low" comp I mean about 8.8:1 with I assume standard VN heads. Good stuff if you want a tough street mo |
Thats the beauty of these. You get the best of both worlds if you want. HSV stock heads, mild cam and these slugs put out 220kw. Or if you put a bigger cam (apart from OE restorers, who puts in stock cams these days) mild headwork, exhaust and these pist
