keithholden Offline
#1 Posted : Monday, 29 December 2008 5:20:06 PM(UTC)
keithholden
Ive removed the linkages and tried to manually push the leaver into third but it wont budge, all other gears work fine.
Any suggestions or is it time for a new box
Cheers Keith.
#2 Posted : Tuesday, 6 January 2009 2:41:09 AM(UTC)
The three speed box has two selectors. One of them does first and reverse the other does second and third.
Inside the box there is a detent system which prevents you from engaging two gears at once.They do fail. Try jiggling the firs/reverse linkage
keithholden Offline
#3 Posted : Tuesday, 6 January 2009 8:34:12 AM(UTC)
keithholden
Cheers Jim,If it works will I still have to replace,repair my box??
