#1 Posted : Thursday, 1 January 2009 1:39:15 AM(UTC)
whats the best tools to linish a crankshaft and inside a block ? cheers
kraul Offline
#2 Posted : Thursday, 1 January 2009 1:27:19 PM(UTC)
kraul
personly unles ur realy gud as a fiter/turner i wouldnt try it. I paid 40buks for my crank to be linished and tidyd up 4my 202. They made sure everything was al the right size.
With how important ur crank is. 40buks is a bargain.
What are u loking at d
ozchevy Offline
#3 Posted : Thursday, 1 January 2009 8:19:52 PM(UTC)
ozchevy
Linishing a crankshaft is best done on a crankshaft grinding machine, however it can be done on a lathe with a 4 jaw chuck. You need to have each journal turning true overwise you will get high and low spots, so it is imperative that each and every journa
HotRodder Offline
#4 Posted : Tuesday, 6 January 2009 11:12:09 PM(UTC)
HotRodder
When this is done by a professional engine rebuilder
how do they supply the bearings like are they available
in a whole range of different sizes.
Edited by user Thursday, 8 January 2009 2:18:20 PM(UTC)  | Reason: Not specified
kraul Offline
#5 Posted : Tuesday, 6 January 2009 11:45:20 PM(UTC)
kraul
they bring it to a certain undersize normaly ten or twenty though undersize. Bearings that are slightly larger are then used. My crank is ten thou for the con rods and 20thou for the main bearings. Any decent engine builder can help you out
#6 Posted : Thursday, 8 January 2009 12:53:26 AM(UTC)
i thought linishing and crank shaft ginding on the mains and big end journals were two different things linishing is smoothing the rough casting on the counter weights and such cheers
ozchevy Offline
#7 Posted : Thursday, 8 January 2009 1:10:13 AM(UTC)
ozchevy
Linishing journals removes lines left by grinding, it doesnt effect the finished size of the journal as all it is removing is compounded heat marks and surface structure lines left by the grinding wheel. Cranks and cams are linished usually with 1000-1200
