rooster1262 Offline
#1 Posted : Sunday, 4 January 2009 2:09:02 AM(UTC)
rooster1262
You are a member of these groups:: Registered
Hi guys how do you tell the difference between a 350 or 400 gear box, in a 71 hq statesman.
Bruce
#2 Posted : Sunday, 4 January 2009 2:19:29 AM(UTC)
TH400 is electric kickdown. TH350 is cable kickdown
rooster1262 Offline
#3 Posted : Sunday, 4 January 2009 3:18:12 AM(UTC)
rooster1262
Is it obvious to the eye on inspection. Is it visible from the engine bay or do you inspect underneath.
Regards Bruce
#4 Posted : Sunday, 4 January 2009 4:54:50 AM(UTC)
Cable kickdown comes off the carby. Electric kickdown solenoid is on the gearbox on a TH400. The other way to tell is the rear mount. TH400 sits up on the crossmember. TH350 has an outrigger bracket hanging off the front of the crossmember. TH400 also has
rooster1262 Offline
#5 Posted : Sunday, 4 January 2009 5:35:47 AM(UTC)
rooster1262
OK its the 400 than. ta
This page was generated in 0.142 seconds.
