#1 Posted : Friday, 9 January 2009 4:34:36 AM(UTC)
HQ fuel inject 308?,after not getting a cheap 350 chev Im asking for some advice.Ive got a hq panelvan and Ive got a t400 and a308 with 3 sets of heads (including big valve hq)and lots of other parts ,etc but I want to know whats the most basic fuel injection I can use to make it a bit quicker because of the trans and statesman doors(heavy).I think its going to be a bit of a slug with this combo.Any advice with thanxz,ps I am not into commodores or the likes so i wouldnt know about their engines but I think vn heads are the go apparently?...Thanxz...jim
Jim in adelaide
vintageholden Offline
#2 Posted : Friday, 9 January 2009 4:43:21 AM(UTC)
vintageholden
VN is the go
get all the ingection from one.....
pickles auctions....get a whole car thats been crashed...
#3 Posted : Friday, 9 January 2009 4:47:47 AM(UTC)
Can I run the whole vn top end and are the exhausts different?shouldve logged in...doh!
munro73 Offline
#4 Posted : Friday, 9 January 2009 5:25:16 AM(UTC)
munro73
yep and yep cams different to
harrop does a intake manifold if you want to run it on carbs
but apart from alloy heads these flow the best
marge pass me my gun
#5 Posted : Friday, 9 January 2009 5:51:43 AM(UTC)
Thanks for ALL that and anyone else can add please.the more i get the clearer it will become,harrops a little expensive for me,ive got lots of parts i should sell to fund this i just want to make sure it will go a bit better than standard,and also do i ha
Edited by user Friday, 9 January 2009 5:52:41 AM(UTC)  | Reason: Not specified
munro73 Offline
#6 Posted : Friday, 9 January 2009 6:24:56 AM(UTC)
munro73
vn onwards are in/ex in/ex all the way through
instead of in/ex in/ex ex/in ex/in
so not only flows better but elimates the old holden hot spot
thats y you need different extractors
#7 Posted : Friday, 9 January 2009 7:47:17 AM(UTC)
Thanxz..Vintageholden and Munro73..I understand now,but 1 more question ,the cam/lifters/pushrods (from a vn engine) all go into a blue block correct?
Jim in adelaide
Edited by user Friday, 9 January 2009 7:49:09 AM(UTC)  | Reason: Not specified
#8 Posted : Friday, 9 January 2009 7:54:29 AM(UTC)
Yes, the whole top end from a VN-VSIII (except roller cam engines cam and lifters) will bolt onto any HT-VL 304/308 bottom end. This includes heads and cam. A better way to do it though is get a complete injected engine and use your sump, pickup and dipst
#9 Posted : Friday, 9 January 2009 7:58:16 AM(UTC)
Thanxz Byron ,I Will...will it go ok like that ? anyone know if it is a big improvement?
Jim in adelaide
#10 Posted : Friday, 9 January 2009 8:23:36 AM(UTC)
vintageholden
build it for straight gas and get gas injection
can run high compression then....
#11 Posted : Friday, 9 January 2009 8:38:58 AM(UTC)
what does that involve? alot? ps havent found the posts ,still looking but i think ive got an idea on how it goes,just have to sell some stuff now......lol
Jim in adelaide
munro73 Offline
#12 Posted : Friday, 9 January 2009 10:41:54 AM(UTC)
munro73
or go the stroker route
#13 Posted : Friday, 9 January 2009 10:52:54 AM(UTC)
just quickly what block is already clearanced from the factory?
Jim in adelaide
#14 Posted : Friday, 9 January 2009 5:07:26 PM(UTC)
Mid VR onwards. The earlier blocks have 5.0L on both sides (lke early blocks have 253 or 308 on one or both sides). The clearanced blocks have a blank pad on both sides.
If we all had the same (g
#15 Posted : Friday, 9 January 2009 5:41:33 PM(UTC)
Thanks Byron.!
Jim in adelaide
Mr.Jones Offline
#16 Posted : Saturday, 10 January 2009 12:18:35 AM(UTC)
Mr.Jones
Jim you may need to search the archived stuff http://www.fastlane.com....?ARCHIVE=true&FORUM_ID=2 the topics with no author are no longer viewable. I swapped from a tired 253 to a inj 5L and had 3X the power and used 1/2 the fuel so I was
Voltaire
#17 Posted : Saturday, 10 January 2009 1:51:29 AM(UTC)
Ive looked twice and cant find it,? Was it hard and if youve got time ,what was your biggest hurdle and how did you get over it ..ps my set up at this stage is 308 blue/hq big valve heads ,t400 (soon via luke in s.a.) and a 3.08 diff.
Jim in adelaide
#18 Posted : Saturday, 10 January 2009 3:46:27 AM(UTC)
#19 Posted : Saturday, 10 January 2009 4:54:32 AM(UTC)
Thanxz again Byron ..Now ill have to do it!!
Jim in adelaide
#20 Posted : Saturday, 10 January 2009 5:31:59 PM(UTC)
Jim there is a guy here in Adelaide that will put injectors into your existing 308 Manifold and then run a commodore fuel rail to get the fuel to them. Then he uses a camira computer to control it all. This is a much cheaper option for getting fuel inje
Guest (5)
