peterwmh Offline
#1 Posted : Friday, 9 January 2009 9:50:22 PM(UTC)
peterwmh
Hi all,
Just completed a 4000km Xmas holiday trek with the EL wagon towing a caravan. Just a couple of small problems along the way, it's dual fuel and when hot it occasionally missed under load on gas (eg climbing a hill) and when on petrol it had a strong petrol smell when running on a hot day (guage was up near the O on NORMAL), but ran well otherwise. No signs of a petrol leak that I could see and when cooler or running on gas the smell wasn't there at all. Any ideas???
Peter
#2 Posted : Saturday, 10 January 2009 1:01:20 AM(UTC)
Peter, the spluttering uphill is probably your HT leads the next step is a blown up airbox.
Can't help with the petrol smell except to suggest you inspect the fuel hoses to the fuel rail and from the regulator.
peterwmh Offline
#3 Posted : Saturday, 10 January 2009 1:30:03 AM(UTC)
peterwmh
Thanks Jim, I'll investigate further!! They tell me changing the HT leads is a bugger of a job, not looking forward to that!!
Peter
munro73 Offline
#4 Posted : Saturday, 10 January 2009 7:55:01 AM(UTC)
munro73
ht leads on an el?
man you should try an eb way harder lol
nah one at a time is the best way
and check your fuel regulator and the fittings to
marge pass me my gun
munro73 Offline
#5 Posted : Saturday, 10 January 2009 11:39:33 AM(UTC)
munro73
and dont smoke
peterwmh Offline
#6 Posted : Monday, 12 January 2009 8:28:14 PM(UTC)
peterwmh
Good advice!! :)
#7 Posted : Wednesday, 14 January 2009 12:03:19 AM(UTC)
Yes it's one of those jobs where you get half way through and wish you had not started on an EB. The last time I did it I did them one at a time and used a bit of coat hanger wire bent into a hook to help out.
The coil lead is best done from underne
Guest (5)
