78XC Offline
#1 Posted : Monday, 12 January 2009 10:37:28 PM(UTC)
78XC
Hi I know it's another engine number question and I tried to get the year of these motors but I just can't find the info My engine numbers are:
1: JG37SD figured this one is Broadmeadows fairlane not sure of year
....34838k
2: JH63WS figured this one Marquis not sure of year
....47189K
Really I'm not sure on anything any help would be much appreciatted.
Edited by user Monday, 12 January 2009 10:41:30 PM(UTC)  | Reason: Not specified
#2 Posted : Tuesday, 13 January 2009 12:20:10 AM(UTC)
JG37SD broadmeadows ZH fairlane july 76
JH63WS brisbane marquis or sportsman july 79
63 was used for ZH marquis (and ZH sportsman i think??) and ZJ sportsman so being july 79 id say ZJ sportsman, check the dizzy, if its ZJ it'll be small shaft and will
78XC Offline
#3 Posted : Tuesday, 13 January 2009 2:54:52 AM(UTC)
78XC
Thanks mate I had a look and it's a points dizzy I can't seem to find anything other than a vacuum valve or switch on the base of the dizzy with an airline coming off it. So they would both be the detuned 351's from after the XB.
Edited by user Tuesday, 13 January 2009 3:39:42 AM(UTC)  | Reason: Not specified
#4 Posted : Saturday, 7 February 2009 4:12:18 PM(UTC)
hi can any one tell me what engine code 5 means on my zh marquis cant seem to find out thanks
#5 Posted : Saturday, 7 February 2009 8:13:53 PM(UTC)
I have a 302 Fairlane 500 and it was a 1 owner and has a points dizzy, Never had electronic set up fitted to it.
Paul351xb Offline
#6 Posted : Sunday, 8 February 2009 2:33:28 AM(UTC)
Paul351xb
XC
T = 351 - 4 venturi ( 5.8 )
P = 302 - 4 venturi ( 4.9 )
N = 250 HIGH COMP. (4.1)
J = 250 LOW COMP. (4.1)
E = 200 LOW COMP. (3.3)
H = 351 4 venturi with extra pollution gear fitted. (NSW)
No listing for engine code 5. Ha
snappa Offline
#7 Posted : Monday, 9 February 2009 12:27:24 AM(UTC)
snappa
Y = 302 (2V)
K = 351 (2V)
R = AUTO - COLOMN
B = FLOOR - FLOOR
351 ZH
351 ZH
#8 Posted : Sunday, 15 February 2009 4:39:24 AM(UTC)
hi i have looked at the plate 10 times it says 5 for the engine code that is very strange it might be a mistake from the factory thanks for your help many thanks teejay
Paul351xb Offline
#9 Posted : Sunday, 15 February 2009 6:49:34 AM(UTC)
Paul351xb
Got me mate. Try ringing Ford. Give them the engine number etc and fingers crossed they should be able to tell you what's supposed to be sitting under the bonnet. Good luck.
#10 Posted : Monday, 16 February 2009 8:06:47 AM(UTC)
thanks for your help my brother works for ford and they cant help me so ill never know lol they said the same codes as u
Paul351xb Offline
#11 Posted : Monday, 16 February 2009 2:56:16 PM(UTC)
Paul351xb
Check the build plate and see if the car was made on a friday or a Monday. Looks like someone got the old stamp a tad wrong which in all honesty wasn't such a rare thing with the quality control back then.
Guest (6)
