Ford_Capri_Gt Offline
#1 Posted : Wednesday, 21 January 2009 8:24:27 AM(UTC)
Ford_Capri_Gt
Hi
I have just brought a ford capri rolling shell from ebay for $600
Dont know if it is a 69 or 70`s model
I havent picked it up yet as when i contacted him he said he had no papers and the car has no tags only the numbers stamped in the radiator support pannel does anyone know if this is enough info for it to be re registered once its ready too.
This is what he wrote:
ford capri rolling shell, was going to be next project but same old story have to get rid of a couple,body is in good condition,rust in usual places ,front of sill panels and front floor an couple small spots around car,1/4 panels,turret,are in great condition has fibre glass bonnet and all moulds,glass,doors,dash, and other various pieces, would suit drag car or restoration,has no tags but has numbers on radiator support panel
Her is a pic also
#2 Posted : Wednesday, 21 January 2009 9:20:35 PM(UTC)
Open the bonnet.
If there are four holes on the heater plenum bulge where the compliance plate would have been riveted on then you have a 1970 onwards model.
If the 4 holes are on the top of the drivers side inner guard about 1/2 way between t
#3 Posted : Wednesday, 21 January 2009 9:47:41 PM(UTC)
OK I miss read your original post as you are wanting to know if your Capri is a 69 or 70's model & I read it a s a 69 or 70 model.
What I wrote above is true but you can now add:
1969 and 1970 models had a welded in cross member behind the gear
#4 Posted : Wednesday, 21 January 2009 10:23:02 PM(UTC)
Ford_Capri_Gt
I havent picked it up yet as it has no papers or tags so he cant give me the vin number only the body/chassis number thats stamped into the radiator support pannel so dont know if the rta will register it once its ready.
Do you know if the rta will acc
#5 Posted : Wednesday, 21 January 2009 10:30:56 PM(UTC)
Ford_Capri_Gt
Also will the chassis number im waiting to get from him tell me what year and type it was ?
Edited by user Wednesday, 21 January 2009 10:49:54 PM(UTC)  | Reason: Not specified
#6 Posted : Wednesday, 21 January 2009 10:41:36 PM(UTC)
#7 Posted : Wednesday, 21 January 2009 10:49:31 PM(UTC)
#8 Posted : Friday, 23 January 2009 7:57:39 PM(UTC)
Ford_Capri_Gt
Just heard back from him this morning and this is the chassis number he gave me.
hey mate got your messages ,just been very busy this week,number on rad support is *ck17jr52728* and stamped on shock tower is 10 71 id say this is build date
also forgot
Edited by user Friday, 23 January 2009 8:00:03 PM(UTC)  | Reason: Not specified
#9 Posted : Friday, 23 January 2009 11:46:37 PM(UTC)
Ford_Capri_Gt
Has anyone replace a gbox tunnel b4 and is it ok to stuff around with that part of the car without having to go through hell to get it approved to go back on the road ?
The number he said was stamped into the shock tower would this be the year it was m
#10 Posted : Saturday, 24 January 2009 7:15:01 AM(UTC)
Well you are in luck and possibly out of luck.
If your body number is CK17 then you either have a 1969 1600GT which does not need a compliance plate or a GTV6 which is worth better money than $600.
As for the tunnel they contain a "horsesh
#11 Posted : Saturday, 24 January 2009 8:43:57 PM(UTC)
Ford_Capri_Gt
Do you know if they stamped the build date into the shock tower
He said its got 10 71 printed into the shock tower would this be its build date ?
I also found out about the gearbox tunnel it has been modified to fit a v8 and the gearbox.Would this mea
Edited by user Saturday, 24 January 2009 10:41:24 PM(UTC)  | Reason: Not specified
#12 Posted : Saturday, 24 January 2009 10:44:55 PM(UTC)
The 'JR' in CK17JR52728 denotes a June 1969 build date. Given that date, and that CK17 at the beginning denotes a GT, you have a 1600GT shell. The 10 71 the fellow is talking about is most likely stamped on the passenger side shock tower and this n
#13 Posted : Saturday, 24 January 2009 11:22:50 PM(UTC)
Ford_Capri_Gt
Thanks for the reply
Its been modified to fit a v8 but im going to look for a origanal 4cyl and put that back into it.
Found a couple but waiting for them to get back to me with the engine numbers to ring revs
#14 Posted : Monday, 26 January 2009 8:55:40 PM(UTC)
Ford_Capri_Gt
I think it may be a 70`s as it has a 140mph speedo where as i heard the 69 only went to 120mph
Cant be any older than 70 though as the seatbelt upper anchorages are on the quarter pannel and not the bpillar.
I ended up getting it but not for the price
#15 Posted : Tuesday, 27 January 2009 7:53:52 AM(UTC)
The 1600GT and 1600XL had full guage clusters with a 120mph speedo. The V6's had a 140mph speedo and a little "v6" near the "rpmX1000" on the tacho.
I
#16 Posted : Wednesday, 28 January 2009 2:47:23 AM(UTC)
I ended up getting it but not for the price he wanted as it needs a lot of work
#17 Posted : Wednesday, 28 January 2009 8:25:29 AM(UTC)
#18 Posted : Wednesday, 28 January 2009 6:28:49 PM(UTC)
Ford_Capri_Gt
Yes the number is what is on the slam pannel so he must of just swaped speedos.
The engine bay has been hacked to pieces and the sills are rusted apart.
I was thinking about getting a front cut and welding a new front on ?
I have found a 70`s 1600
#19 Posted : Wednesday, 28 January 2009 11:59:20 PM(UTC)
Ford_Capri_Gt
Will get some better eng bay pics when the sun isnt so bright
[IMG]http://i707.photobucket.com/alb
#20 Posted : Thursday, 29 January 2009 12:14:24 AM(UTC)
That is some bad A pillar rust but Quinton's was nearly as bad and he brought it back:
http://www.fordaustralia...m/showthread.php?t=33896
Really you would have nothing to lose by trying to fix it except maybe time and effort.
Guest (10)
