cheezel308 Offline
#1 Posted : Thursday, 22 January 2009 1:10:39 AM(UTC)
cheezel308
howdy my lj was factory drum brake front
and a couple of years ago i put a disk brake front plus booster/master off a lc on it.
ive never really been happy with the brakes (all looks fine pads/shoes and about 2 months ago i put new wheel cylinders on)
so it seams two brake 90% front also the brake pedal doesn't return all the way not allways (i have to lift it about half an inch with my foot!)
any ideas.....cheers
#2 Posted : Thursday, 22 January 2009 1:42:10 AM(UTC)
put a spring from the pedal to under the dash to help it return
#3 Posted : Thursday, 22 January 2009 2:04:06 AM(UTC)
Did you also fit the correct small wheel cylinders & matching shoes on the rear, when you did the conversion ?
cheezel308 Offline
#4 Posted : Thursday, 22 January 2009 2:34:09 AM(UTC)
cheezel308
terry
i dont remember if the diff was outta the lc (disk front)
or the diff that was in the lj..also when i got the cylinders i wasnt told about drum/disk cylinders or shoes!?!
how can i tell what i have??
#5 Posted : Thursday, 22 January 2009 3:16:35 AM(UTC)
When you fitted the new rear cylinders, can you remember if there were 2 push rods from the cylinders to the shoes, or did the pistons butt up directly to the shoes.
cheezel308 Offline
#6 Posted : Thursday, 22 January 2009 4:03:36 AM(UTC)
cheezel308
the pistons seat flush and buttered up to the shoes
i think.
cheezel308 Offline
#7 Posted : Saturday, 24 January 2009 3:26:00 AM(UTC)
cheezel308
so im guessing the push rod style cylinder is the disk brake model!?!
can i still run the same drums,if i change to smaller shoes and cylinders!?!
HELP ME TERRY!
#8 Posted : Saturday, 24 January 2009 4:15:41 AM(UTC)
Originally posted by cheezel308
...and buttered up to the shoes
#9 Posted : Saturday, 24 January 2009 8:01:56 AM(UTC)
cheezel308 Offline
#10 Posted : Saturday, 24 January 2009 6:32:19 PM(UTC)
cheezel308
its low and soft....ive bleed them that many times its not funny!
how do i tell if the booster or master cylinder are stuffed!?!
#11 Posted : Sunday, 25 January 2009 12:37:23 AM(UTC)
OK
Low & soft means there is air in the system or perhaps the booster pushrod doesnt match the piston in the m/cyl. The easiest way to find if the problem is in the calipers or rear wheels is to temporarily clamp the brake hoses. If the pedal height b
Edited by user Sunday, 25 January 2009 12:39:05 AM(UTC)  | Reason: Not specified
munro73 Offline
#12 Posted : Sunday, 25 January 2009 9:48:12 PM(UTC)
munro73
i know on the hqs you have a proputing ? valve mid way down the chassis that
needs to be changed are toranas like this 2?
marge pass me my gun
#13 Posted : Sunday, 25 January 2009 10:18:07 PM(UTC)
The proportioning valve half-way along the chassis is only seen on the HQ series. HJ & later Holdens (including LH-LX Toranas) have theirs mounted with the differential switch block on the RH inner guard.
Disc braked, 6-cyl LC/LJ Toranas have no propor
cheezel308 Offline
#14 Posted : Monday, 26 January 2009 3:17:55 AM(UTC)
cheezel308
the nipples are at the top.....im gunna try clamping the rear brakes.
cheezel308 Offline
#15 Posted : Friday, 6 February 2009 7:19:05 AM(UTC)
cheezel308
does anyone know a good brake place in melbourne where i can spend my rudd bonus!?!
cheezel308 Offline
#16 Posted : Wednesday, 11 February 2009 2:18:29 AM(UTC)
cheezel308
i bit the bullet,car goes to my mechanic thursday....im over it!!! :(
Guest (11)
