#1 Posted : Thursday, 22 January 2009 7:37:36 AM(UTC)
My ute has a 9" diff and the bugger is leaking out of the seal where the tail shaft enters. if i undo the housing will the pinon assembly come out easily then i can just replace the seal or is is harder than that?
#2 Posted : Thursday, 22 January 2009 8:34:25 AM(UTC)
You would only have to worry about re-setting the bearing pre-load on the pinion bearing upon re-assembly I would imagine?
This page was generated in 0.066 seconds.
