oHQo Offline
#1 Posted : Saturday, 24 January 2009 3:36:21 AM(UTC)
oHQo
Hey guys new here. Wondering if anyone could help with identifing an original 308 4 barrell manifold? What is the difference with these to other red motor manifolds? Thanks for your help.
#2 Posted : Saturday, 24 January 2009 4:23:56 AM(UTC)
THE HQ MANIFOLD FACES (THE PART THAT BOLTS TO THE HEAD) WONT HAVE ANY EXTRA HOLES LOCATED IN THE MIDDLE...ie IT WILL ONLY HAVE THE BOLT HOLES TO GO IN THE HEAD....NO EXTRAS.!ps sorry about the caps lock on ...doh!
Jim in adelaide
Edited by user Saturday, 24 January 2009 4:24:34 AM(UTC)  | Reason: Not specified
JBM Offline
#3 Posted : Saturday, 24 January 2009 4:49:53 AM(UTC)
JBM
The HQ/J and LH manifold doesnt have provision for the EGR ports used on the pollution red/blue/black heads, ie 4 inlet ports only on each side.
James
You only have to be in front at the end o
Edited by user Saturday, 24 January 2009 4:53:24 AM(UTC)  | Reason: Not specified
oHQo Offline
#4 Posted : Saturday, 24 January 2009 5:39:15 AM(UTC)
oHQo
Is the HQ the only one with the vacuum thingy and heater (?) outlet on the same side? Is there any way of telling by the numbers on the runners? Been a long time since I have looked at a stocko one. Thanks guys.
#5 Posted : Saturday, 24 January 2009 5:49:23 AM(UTC)
HT, HG, HQ, LH, pre-ADR27A LX and other LX/HX/HZ without ADR27A are all the same basic manifold. They are water heated and have no exhaust crossover provision. There is a choke operator on the drivers side below the carb. HT and HG have an extra hole tape
oHQo Offline
#6 Posted : Saturday, 24 January 2009 7:30:45 AM(UTC)
oHQo
Thanks again guys.
#7 Posted : Saturday, 24 January 2009 8:06:31 AM(UTC)
#8 Posted : Saturday, 24 January 2009 6:50:29 PM(UTC)
? HT-HQ have a choke operator (thermostat) attached to the manifold on the side of the plenum. Thats what the heat tube that goes to the exhaust is attached to. Its the same basic operator mechanism with bi-metal spring that sits on the side of the later
oHQo Offline
#9 Posted : Saturday, 24 January 2009 10:33:12 PM(UTC)
oHQo
So if you have a set of genies or similar you cant hook up the choke on a rochester then?
#10 Posted : Saturday, 24 January 2009 11:57:12 PM(UTC)
Yes, just put a mechanical (like L34) or electric choke conversion on it. You can also get extractors with a heat tube wrapped around one tube.
If we all had the same (good) taste, who would buy
