#1 Posted : Wednesday, 17 November 2004 3:33:00 AM(UTC)
Got a Camaro that has a voltmeter but no idiot light.
When driving the volts will gradually drop down from around 13 to very low, and sometimes at night while idling for a long period like at a M<acdonalds or something the car will stop. Alternator has new brushes, regualtor and other bits, battery is new, (and it was doing it with the old battery) .
All leads/earths have been cleaned.
Any suggestions?
Any Australian alternators that will replace the crummy Delco, and does it need a idiot light to generate?
#2 Posted : Friday, 19 November 2004 4:59:34 AM(UTC)
Also you can see the voltmeter dropping as you drive.
#3 Posted : Saturday, 20 November 2004 5:18:42 AM(UTC)
John
At the risk of telling you something you already know, the easiest way to see if the alternator is doing the job is put a multimeter (on the volts setting) across the battery whilst it is running. Raise the revs a little above idle, and the vo
#4 Posted : Saturday, 20 November 2004 5:19:37 AM(UTC)
John
#5 Posted : Saturday, 20 November 2004 6:00:04 AM(UTC)
Thanks Matt there is a voltmeter in the car so we know what the alternator is doing. My thoughts were that maybe there is a small break in the windings somewhere and as the motor gets hot the windings expand and the break opens up.
There is only a standa
#6 Posted : Saturday, 20 November 2004 9:49:40 AM(UTC)
You do need an idiot light for it to charge...it provides the initial excitation...from memomy to the DF or dynamo feild terminal.
#7 Posted : Saturday, 20 November 2004 9:03:45 PM(UTC)
Sounds like a plausable theory John. I've had this sort of thing happen before with the lacquer on the windings breaking down (electrically) at higher temperatures then working once again when it had cooled down. I proved it in my case by having access to
#8 Posted : Saturday, 20 November 2004 9:40:18 PM(UTC)
This too is possible, however, before you do that, can you confirm that this alternator and voltmeter is the original configuration. If not, then FastEHHolden's solution is probably more likely (using the light instead of the guage). If it IS the origin
#9 Posted : Sunday, 21 November 2004 8:45:51 AM(UTC)
This is original factory wiring, no idiot light. I can only assume there is a resistance or something in there to provide a current draw to tickle the alternator.
