bundybluedog Offline
#1 Posted : Wednesday, 28 January 2009 7:30:28 AM(UTC)
bundybluedog
flat top pistons in a 304 with standard gaskets gets acording to acl 9.3:1 compression 78cc. mine will be flat tops with 86cc whats the compression ration with a standard gasket and what sized gasket would i need for 9:1 comp.
#2 Posted : Wednesday, 28 January 2009 7:25:18 PM(UTC)
No it doesnt. It is 9:1 with zero deck. Holden engines run on average approx .030" below the deck, reducing the comp ratio even greater.
http://www.aclperformanc...lden5.0LCastPistons.htm
If this is where you got your info from, it is wrong. I
#3 Posted : Wednesday, 28 January 2009 9:15:56 PM(UTC)
I spoke to a mathematician friend of mine and this was his answer:
" Assuming zero deck height, I calculate the swept volume of the piston to be 647.4 cc. Assuming this
is correct, with 86cc chambers, the CR should be close to 8.5:1
Edited by user Wednesday, 28 January 2009 9:17:08 PM(UTC)  | Reason: Not specified
#4 Posted : Wednesday, 28 January 2009 9:39:19 PM(UTC)
#5 Posted : Thursday, 29 January 2009 7:37:20 AM(UTC)
bundybluedog
thanks for the help, im not running zero deck height just the usualy skim of both heads and block. so i guess im around the 8:1 to 8.5:1 so my engine should be good for a turbo...
