bradk Offline
#1 Posted : Wednesday, 28 January 2009 6:44:49 PM(UTC)
bradk
What are a set of L34 heads worth these days?
#2 Posted : Thursday, 29 January 2009 1:14:32 AM(UTC)
Was thanked: 632 time(s) in 594 post(s)
Genuine L34 heads off an original L34? Or heads done to L34 specs?
bradk Offline
#3 Posted : Thursday, 29 January 2009 7:33:55 PM(UTC)
bradk
I was told they were of a an L34. They are currently sitting on my 253 that I could be wrecking if it worth the effort.
How can one tell that are genuine heads?
The bloke I bought the car off is realy genuine so I believe him explicitly.
#4 Posted : Thursday, 29 January 2009 11:17:04 PM(UTC)
what are the casting numbers in the oil valley?
#5 Posted : Friday, 30 January 2009 7:58:41 AM(UTC)
Problem I think is proper L34 heads wont work on a 253. The valves hit the block deck if I remember correctly.
L34 heads are just modified HQ red heads, done by Dave Bennett (also from memory). But to be original heads theyll be the right casting dates,
JBM Offline
#6 Posted : Friday, 30 January 2009 9:23:44 AM(UTC)
JBM
The heads are as per HK1837s post.
They will have the same casting number as regular heads, bigger valves and a needle roller bearing on the rocker arm pivot.
They were done as a batch by Dave Bennett before the L34 was released so cast date is critical
bradk Offline
#7 Posted : Friday, 30 January 2009 10:08:24 PM(UTC)
bradk
Cheers JBM
that puts a better light to it. I will leave it on the 253 for my next project. The engine is worked a bit and is rated a fair bit above standard horsepower.
