theNEWT Offline
#1 Posted : Friday, 30 January 2009 4:55:23 AM(UTC)
theNEWT
Hi folks.....please excuse my ignorance.
I recently acquired an off road vehicle that has a Holden red 202 motor fitted. I have been told it has a yella terra head. The head has the small diameter spark plugs..which I am told are not standard on normal 202 heads, hence suggests it might be a YT head. I require a replacement set of extractors (headers) as those fitted have large oxide induced vented areas at their lowest point....ie BIG holes. My question is: Does this yella terra head have 12 ports or 6? I assume 12. I know I can take them off ...but would prefer to find extractors to fit first if possible. Can I fit extractors from a blue or black motor, as long as they have 12 ports?,,,,Does the yella terra head have 12 ports? Any help appreciated....thanks in advance.
The motor is mid-mounted in a Chev Luv pickup. Vehicle built for mud running.
heres da beasty motor...oodles of power seems to come from this thing. Have ran new gaskets etc through the Holley....still setting her up....little flooding at idle. Still a bit to do, but coming along.
Newt
David Offline
#2 Posted : Friday, 30 January 2009 7:14:44 AM(UTC)
David
Hi Newt, Carlton,
Carlton, I think Newt is looking for help, not criticism. I expect someone who knows what they are talking about will help him.
Newt, Im no expert, but I think red heads were 9-port heads. Maybe someone fitted a 12-port head and pa
theNEWT Offline
#3 Posted : Friday, 30 January 2009 7:20:08 AM(UTC)
theNEWT
Thanks David...yes..my understanding is that the red heads (original) were 9 port...but Im not sure if this head is 9 or 12 being yella terra...is there another way of telling, rather than pulling the extractors off? I have access locally to a set of 12 p
#4 Posted : Friday, 30 January 2009 7:24:55 AM(UTC)
Its a 9 port unless its one of those old Bath12000 or whatever they were called Yella terra Conversion. In any case you need red extractors. To tell for sure what is the casting number off the head? What is the engine number prefix?
___________________
theNEWT Offline
#5 Posted : Friday, 30 January 2009 8:11:23 AM(UTC)
theNEWT
Cheers....Ill check the casting numbers out tomorrow..
HQforme Offline
#6 Posted : Friday, 30 January 2009 10:24:08 AM(UTC)
HQforme
If you need new ones, surely you can afford a few days without the vehicle? Pull them off, have a look, then get what you need!
"Silly modern cars"
Mr Void Offline
#7 Posted : Friday, 30 January 2009 7:17:46 PM(UTC)
Mr Void
Id be very surprised if it was a 12-port
___________________
Why are you reading this, you should be looking up there^^
- HJ tonner looks and goes like a rhino on heat! -
___________________
FastEHHolden Offline
#8 Posted : Friday, 30 January 2009 7:46:01 PM(UTC)
FastEHHolden
The casting number will not ID it as a YT head....the only way to know is to pull the manifold off and look at the inlet ports..or pull the rocker cover and look for double valve springs...or pull the head off and see whats written on the valve head.
#9 Posted : Saturday, 31 January 2009 2:10:56 AM(UTC)
But it will tell for sure if its a red or blue, and it doesnt matter if its a red 9 or 12 port as the extractors will still be the same.
If we all had the same (good) taste, who would buy all the
theNEWT Offline
#10 Posted : Saturday, 31 January 2009 3:20:21 AM(UTC)
theNEWT
Casting number on the head is : 2811930
Havent looked at the block yet.....but it is a 202, thats for certain.
So....do the one set of extractors fit both 9 and 12 port?
#11 Posted : Saturday, 31 January 2009 3:54:38 AM(UTC)
No. If it is a Yella Terra red head 12 port conversion they will be the same as a 9 port. Factory Holden 12 port (blue/black) heads use different extractors.
However that casting number tells you its a red head, so just buy red head extractors. The head
#12 Posted : Saturday, 31 January 2009 3:57:55 AM(UTC)
9 port and 12 port extractors are not interchangable
theNEWT Offline
#13 Posted : Saturday, 31 January 2009 4:05:44 AM(UTC)
theNEWT
I very much appreciate the patience and help from members here...as I stated early..please excuse my ignorance...
Thanks for the clarification - I need a set of extractors to fit a 9 port head. The 9s and 12s are not interchangeable...which is what I o
#14 Posted : Saturday, 31 January 2009 4:19:14 AM(UTC)
Lets clarify this a bit.
Red heads are originally 9-port. Blue/Black heads are 12-port.
Extractors are not interchangeable between these two, because the bolt patterns are different.
Where the confusion comes in, is a red 9-port head can be modif
theNEWT Offline
#15 Posted : Saturday, 31 January 2009 4:55:46 AM(UTC)
theNEWT
theNEWT Offline
#16 Posted : Sunday, 1 February 2009 2:30:30 AM(UTC)
theNEWT
For those interested: A couple of closeups of the rocker gear after removing the cover.
#17 Posted : Sunday, 1 February 2009 4:24:01 AM(UTC)
Definiety HQ 202 head. Looks like head may have had some work though by the springs and retainers.
theNEWT Offline
#18 Posted : Sunday, 1 February 2009 5:16:30 AM(UTC)
theNEWT
#19 Posted : Sunday, 1 February 2009 6:05:08 AM(UTC)
Yella terra is a product. Company was Perfectune, established by Dave Bennet. He cut his teeth building heads for Holden 6s and then later for HDT (XU-1 and L34). If you Google him youll find his HR with modified head and his HK GTS327 he used to drag rac
CherryBomb Johnston Offline
#20 Posted : Monday, 2 February 2009 7:15:50 PM(UTC)
CherryBomb Johnston
Blue heads are also reconized by there shear intake manifold Port size. Reds are tiny in comparison.
If you hold a red and blue head together, its clear why a set of blue/black extractors/ headers wont fit a red head and vise versa.
There is really tht
"Because stock sucks"
Guest (15)
This page was generated in 0.099 seconds.
