bundybluedog Offline
#1 Posted : Sunday, 1 February 2009 7:46:08 AM(UTC)
bundybluedog
Is there much benifit in nitriting a crank? and will shot peening my rods(a9l) boost there HP rating. i wanna build a solid bottom end that will alow for power increases if i choose to later.
greenhj Offline
#2 Posted : Sunday, 1 February 2009 10:20:49 PM(UTC)
greenhj
In all honestly, new rods are cheap these days, by the time you cracktest,new bolts,close and hone,little end hone if required and shot peen, another 100 bucks will have you in a stronger, brand new set of i beams.
COME do a set of i beams, they rate t
Edited by user Sunday, 1 February 2009 10:26:57 PM(UTC)  | Reason: Not specified
knute Offline
#3 Posted : Monday, 2 February 2009 12:41:44 AM(UTC)
knute
even a good cast offering should be man enough
i had a 750 norton combat commando, which at peak revs hit the (then) limits of piston speed, which was 4000 ft per second or per minute, cant remember which
it had hepolite cast pistons as standard, an
#4 Posted : Monday, 2 February 2009 5:41:40 AM(UTC)
"nitrited"?
This guy is a moron
Dont bother responding to his ill-conceived dreams
greenhj Offline
#5 Posted : Monday, 2 February 2009 6:48:18 AM(UTC)
greenhj
Originally posted by knute
hi greenhj, hows the weekend m8 ?
#6 Posted : Monday, 2 February 2009 7:16:33 AM(UTC)
bundybluedog
thanks for your help guys. combover you can go **** yourself your week as piss.
knute Offline
#7 Posted : Monday, 2 February 2009 8:56:10 AM(UTC)
knute
the usual hangout are busy with macrame and quince jam
This page was generated in 0.091 seconds.
