Is there much benifit in nitriting a crank? and will shot peening my rods(a9l) boost there HP rating. i wanna build a solid bottom end that will alow for power increases if i choose to later. |
Havent you learnt anything from that guy that gives sermons at church?...Captain whats his name. |
Thanks: 8 times Was thanked: 16 time(s) in 14 post(s)
In all honestly, new rods are cheap these days, by the time you cracktest,new bolts,close and hone,little end hone if required and shot peen, another 100 bucks will have you in a stronger, brand new set of i beams. COME do a set of i beams, they rate t Edited by user Sunday, 1 February 2009 10:26:57 PM(UTC)
| Reason: Not specified
even a good cast offering should be man enough
i had a 750 norton combat commando, which at peak revs hit the (then) limits of piston speed, which was 4000 ft per second or per minute, cant remember which
it had hepolite cast pistons as standard, an
"nitrited"?
This guy is a moron
Dont bother responding to his ill-conceived dreams
quote: Originally posted by knute
hi greenhj, hows the weekend m8 ?
thanks for your help guys. combover you can go **** yourself your week as piss. |
the usual hangout are busy with macrame and quince jam
