lxtoranahzute Offline
#1 Posted : Tuesday, 3 February 2009 8:57:14 AM(UTC)
lxtoranahzute
I have a hx statesman caprice wich i robed the doors off to fit to my hz ute.I intend to have the electric windows in the ute and i was wondering what would be easyest to do.Do i remove all necasary electrical components from the statesman(mamoth job by the looks)and fit it to the hz ute, or do i come up with my own system is it posible? (i do have a little bit of a brain about me)Also is it worth the efort to go for the statesman dash keeping in mind i have to recover some cost on the statesman when i off load it.Whats a raped hx statesman caprice worth lol
toptrix
#2 Posted : Tuesday, 3 February 2009 10:00:31 AM(UTC)
lxtoranahzute
Oh and how hard is it to remove the chrome from the tops of the doors without damaging it and will it go back on with a nice fit,i think i need to do this to prep them for painting
toptrix
#3 Posted : Tuesday, 3 February 2009 4:05:56 PM(UTC)
You could fit the entire dash and A/C including wiring from the statesman into the ute. Relatively simple to do when they are side by side. Does require some extra holes in the firewall.
If we al
#4 Posted : Wednesday, 4 February 2009 6:16:36 AM(UTC)
lxtoranahzute
The firewalls look a fairbit different.i would have to cut and fit a fair junk for a/c in the hz.My arm lives on the window sill anyway so a/c dont phase me.
toptrix
#5 Posted : Wednesday, 4 February 2009 6:31:45 AM(UTC)
Same firewall, just 4 holes need drilling. Statesman dash is a bolt in fit otherwise.
#6 Posted : Wednesday, 4 February 2009 6:43:45 AM(UTC)
lxtoranahzute
the hole for the a/c is bigger then the heater unit hole,the highs and lows of the firewall surface are different but thats just my observastions
toptrix
#7 Posted : Wednesday, 4 February 2009 6:56:18 AM(UTC)
No, theyre the same size. Theres an extra 32mm hole in the middle for the vacuum line and harness and there is 3 hidden overlapping 16mm holes down low for the heater pipes. Aircon evaporator looks bigger but it fits in the same place.
________________
#8 Posted : Wednesday, 4 February 2009 7:00:10 AM(UTC)
lxtoranahzute
ok my eyes decieve me lol i will investigate further.
toptrix
#9 Posted : Wednesday, 4 February 2009 7:40:20 AM(UTC)
lxtoranahzute
would the statesman brakes be beter then the hz utes ashuming they bolt up the same,what else do you reckon the hz will benifit from the statesman except for the obvious
toptrix
Edited by user Wednesday, 4 February 2009 7:48:35 AM(UTC)  | Reason: Not specified
#10 Posted : Wednesday, 4 February 2009 8:04:15 AM(UTC)
#11 Posted : Monday, 9 February 2009 12:06:42 AM(UTC)
lxtoranahzute
Statesman drivers door has Too much bog to mess with so dose the electric window mechanisium bolt up the same as the mecheanical to a std door ?
Not all TOOLS are usefull
#12 Posted : Monday, 9 February 2009 12:22:50 AM(UTC)
Yes.
#13 Posted : Monday, 9 February 2009 12:40:47 AM(UTC)
lxtoranahzute
Cheers Dr Terry
Guest (8)
