basketcasebear Offline
#1 Posted : Wednesday, 4 February 2009 4:32:45 AM(UTC)
basketcasebear
hey fellas,
what is the diff between diesal oil, and petrol oil.?
why are they different, and would a good quaulity diesal oil be good for a petrol engine?? or not, and why?
bcb
said the weathercock to the wind,> "how tedious and monotonous you are, can you not blow in any other direction, but in my face!"
and the wind did not answer, it just laughed in space.
k.g/
DOH!!!
knute Offline
#2 Posted : Wednesday, 4 February 2009 4:47:57 AM(UTC)
knute
hi bcb
i started using a dual rated oil for my harley, now thats ALL i use for any oil change
eg SG/CD or whatever the latest specs are
diesel lube rocks, dual purpose is the ultimate
THE OPINIONS EXPRESSED ABOVE ARE NOT NECESSARILY ANY USE TO
#3 Posted : Wednesday, 4 February 2009 4:51:09 AM(UTC)
short answer is no. diesel oils have higher viscosity to run at higher temps and have more detergents. they are good for flushing but will eventually cause loss of compression and overcleaning of seals and make them leak
#4 Posted : Wednesday, 4 February 2009 10:02:46 AM(UTC)
basketcasebear
thanks, ewez blokes, will consider both answers,
bcb
DOH!!!
greenhj Offline
#5 Posted : Wednesday, 4 February 2009 7:48:23 PM(UTC)
greenhj
the diesel oils are primarily used because most contain zddp, which is absolutely critical for highly loaded, hard wearing areas in an engine, such as flat tappet camshafts.
Since the advent of catalytic convertors, the zddp levels have steadily been r
#6 Posted : Thursday, 5 February 2009 1:52:40 AM(UTC)
add a bottle of nulon or wynns supreme or alittle of both at your next oil change i bet you notice the the difference cheers
Guest (6)
This page was generated in 0.088 seconds.
