BAD WB Offline
#1 Posted : Tuesday, 10 February 2009 2:27:22 AM(UTC)
BAD WB
Are all VR onwards 304 blocks clearenced for a 355 or is it only selected blocks, also will a 383 crank fit or will it need to be clearenced futher?
#2 Posted : Tuesday, 10 February 2009 3:04:27 AM(UTC)
Its only the ones that are blank on the sides where the early blocks have 5.0L (about mid VR onwards). They are built to be 350 cubes, 355 is just a 30 thou overbore. Talk to COME about the 377 (383 at +0.030) cube stroker and rod clearancing. With the Ch
greenhj Offline
#3 Posted : Tuesday, 10 February 2009 3:57:09 AM(UTC)
greenhj
needs more clearancing for 3.75" crank and typical chev rods, theres also a real good chance of hitting water, meaning a weld and grout job as well.
If it were me (and it likely will be next time) I would seriously look at a crank set up for HONDA rod
Edited by user Tuesday, 10 February 2009 3:59:53 AM(UTC)  | Reason: Not specified
This page was generated in 0.022 seconds.
