tanart Offline
#1 Posted : Tuesday, 10 February 2009 10:52:34 PM(UTC)
tanart
Would a 9inch diff fit a HT GTS lowered 2inches with a standard 10 bolt tank? im replacing the current bathurst tank with a standard tank. The bathurst tank was modified to suit the 9inch diff. Has anyone fitted one of these with a standard tank without issue?
#2 Posted : Wednesday, 11 February 2009 12:14:42 AM(UTC)
Underside of 16 and 25 gallon tanks the same, so if you modified the 25 to fit you will have to modify the 16.
Warren
Davesmonaro68 Offline
#3 Posted : Wednesday, 11 February 2009 1:14:58 AM(UTC)
Davesmonaro68
Mine was 4 inches lower (but very stiff tight susp)and had i issue which wasnt the tank clearance, it was the new sway bar i ordered was to suit the sals not the nine inch and rubbed the back of the housing
MONARO!!WHERE!!NICE
MONARO!!WHERE!!NICE
tanart Offline
#4 Posted : Wednesday, 11 February 2009 3:44:05 AM(UTC)
tanart
thanks guys
#5 Posted : Thursday, 12 February 2009 6:01:26 AM(UTC)
Yes a nine in will fit a stock tank with a lowered car by 2 inches.
10 bolt housing is taller than a 9 inch.
I have had both in my car, 10 bolt hit the floor in front of the tank, hence the factory bump for 10 bolt models.
The nine inch does not
tanart Offline
#6 Posted : Thursday, 12 February 2009 10:31:17 PM(UTC)
tanart
thanks again
