bradk Offline
#1 Posted : Wednesday, 11 February 2009 7:00:43 AM(UTC)
bradk
I am trying to fit a 5lt VN into my Hz wagon and the mounts on the engine are set back. Do I need to fit origanal mounts 253 / 308 to this engine to make them fit. I am out by about 3 inches.
Edited by user Wednesday, 11 February 2009 7:02:05 AM(UTC)  | Reason: Not specified
#2 Posted : Wednesday, 11 February 2009 7:03:11 AM(UTC)
bradk Offline
#3 Posted : Wednesday, 11 February 2009 7:10:40 AM(UTC)
bradk
Cheers for that and that was a quick reply.
#4 Posted : Wednesday, 11 February 2009 7:34:55 AM(UTC)
Also use the HQ-WB dipstick and bend the tab a bit so it goes under the VN exhaust manifold bolt. Will be obvious when you get there. When I did this in my HZ I also kept the VN water pump, spacer and viscous fan and just changed to a 6cyl HZ shroud (almo
