#1 Posted : Thursday, 12 February 2009 8:07:35 PM(UTC)
Hi everyone
Can anyone tell me what the various Banjo axle codes actually mean.
Mine is a G95 code but not sure what the difference is between this and the other codes.
Thanks for any tips
Paul
#2 Posted : Thursday, 12 February 2009 10:44:14 PM(UTC)
The G numbers are the option numbers for Banjo diff ratios but only for HK/T/G/Q & LC/J series, HJ/LH onwards used different option numbers. The Chev 10-bolt (HK/T/G) & Holden 10-bolt (HQ) also used G numbers but you only asked about the Banjo diffs.
M
JBM Offline
#3 Posted : Friday, 13 February 2009 6:05:45 AM(UTC)
JBM
With ref to the diff codes whats the difference between the "G" codes above and a "GU" Banjo and the other "GV" codes?
James
#4 Posted : Friday, 13 February 2009 9:09:57 AM(UTC)
Different codes for different model series. HK/T/G & LC/LJ only used G codes regardless of the diff type. GV codes were introduced for the new Holden 10-bolt fitted to HQ V8s. In HQ, G was used for Banjo diffs only.
HJ/LH onwards used a mixture of GV &
Edited by user Friday, 13 February 2009 9:11:10 AM(UTC)  | Reason: Not specified
