lxtoranahzute Offline
#1 Posted : Friday, 13 February 2009 12:26:29 AM(UTC)
lxtoranahzute
The torana use to have parkers then low beam but when you flickid it to high then off again high beam would stay on,i later realized that there were 2 high beams ? 1st high would light up further ahead and the second lit up closser in front aswell as the 1st high beam.if a car was coming and i went to dip it would just bring up the 2nd high so when i went to hi beam i had to make sure i flicked the indacator switch forward then back and then forward just so i could dip to low beam straight away after high so i wouldnt blind anyone,not that their bright.Was this a fault or is it normal ? I now have no low beam and my guess is that its the relay as the low beam wire will activate the high beam but neither wires will activate low beam and i also had no reverse light before but now i do.Ideas anyone
Not all TOOLS are usefull
Franklin Offline
#2 Posted : Friday, 13 February 2009 4:15:21 AM(UTC)
Franklin
My Dad had an 77 LX with a similar problem - theres a wire up at the top of the column at the indicator/high beam stalk end which unsoldered itself. Youll have to take off the steering wheel to gain access, but once you do, itll be obvious if thats the p
#3 Posted : Friday, 13 February 2009 5:38:32 PM(UTC)
lxtoranahzute
cheers,the hi beam stalk was seized when i got it so i spayed some inox in there but i will check out what you suggested
#4 Posted : Sunday, 15 February 2009 10:19:28 PM(UTC)
lxtoranahzute
Cheers franklin, The white wire had broke and the black wire wasnt far off aswell so i got my lights back but i still have to do the double dip thing with the high beem
#5 Posted : Sunday, 15 February 2009 11:49:46 PM(UTC)
Its not actually a double dip thing. There is only one high beam & one low beam..
The column flasher/dip switch has two functions. The first is that it simply dips between high & low when the headlights are on. The second is a headlight flasher when th
#6 Posted : Thursday, 19 February 2009 8:29:04 AM(UTC)
lxtoranahzute
I know what your saying Dr Terry but mines different,the stalk stays where i put it,i dont have to hold it,cant do the flashy cops are ahead thing lol.with ignition and lights on,going into to high the relay clicks(stalk forward)Then move it back relay cl
Franklin Offline
#7 Posted : Thursday, 19 February 2009 10:06:58 AM(UTC)
Franklin
excellent news! there is a wealth of knowledge on this forum and its great to share and learn too. My Dads LX was a 77 chamois coloured SL with 2850, t-bar auto, heated rear window, RTS, economy light, over riders and he fitted aunger rear louvre and hea
